Hi, not too sure where to post this, but i guess here should be fine:
I've got a avi video file, compressed with xvid and ac3 audio stream which i obtained. Unfortunately, the speed of the video is slow. The audio and video are in sync but i feel that it's slower than usual 'cos the voice is in this deep slo-mo voice, that occurs when u slow an audio file. Is there anyway to speed up the file such that it will be back to normal and still in sync?
Thanks a million.
Results 1 to 11 of 11
Forgive the Noob
post you computer config.
free video player,convert,decoder sdk
http://www.nvideo-tech.com -
i dun think it's 'cos of my pc being lousy but instead it's the video file at fault, all my other files work. Here's my specs anyway:
Processor: Pentium 4 3.0GHz
Mobo: ASUStek P5GD1 (Intel 915P)
Gfx: PX6600GT Extreme 128MB PCI-E
Ram: 1024GB Kingston DDR400
Display: SAMSUNG SyncMaster 710N
Storage: 160GB SATA MAXTOR
Optical Storage: SONY Combo Drive & Dual Layer
PSU: AcBel 400W PSU
Audio: Onboard 8.1 Channel
OS: Windows XP Professional SP2Forgive the Noob -
Can you drop it in Gspot and post a screenshot of the results? Blank out the name if you like. It sounds like it may have been encoded at the wrong framerate. You may be able to adjust that in Virtualdub.
right..will do when i get home....currently at me workplace.
Forgive the Noob -
hmmm...my bad. Upon closer scrutiny, the video and audio is indeed out of sync by a few milliseconds.
Forgive the Noob -
here's an update...i extracted the ac3 stream and converted it into a wav file using ac3tools. When i play the wav file on WMP, it plays perfectly, no slo mo thing.
I tried muting my video and played the video and the wav file at the same time. Nope it's not in sync. They're at totally different rates. So could any of u guys here help me out with the next step? Not too sure what to do now.Forgive the Noob -
You can try Remultiplexing the audio and video with VirtualDubMod. First try with the source's AC3 audio. If that doesn't work, try with the WAV file you created from it.
In VirtualDubMod, open your source file. Select Video -> Direct Stream Copy. Select File -> Save As... and save as a new AVI file. This will remux the video and the original AC3 audio without reencoding either.
Then select Streams -> Stream List. Click on the AC3 stream and then the Disable Button. Click on Add and add the WAV file you created earlier. If you want to compress that WAV audio right click on the stream and select Full Processing Mode. Right click on it again and select Compresssion... Select the compression codec you want and it's parameters. Finally, select File -> Save As... and save the results. -
but the thing is that the video speed is different from the 'good' audio speed. The video speed is slower.
Forgive the Noob -
Then change the video speed using VirtualDubMod's Source Rate Adjustment: Video -> Frame Rate. In the top section of the dialog select a different source frame rate. This is just a guess, but try changing the frame rate to 29.97 and using your WAV file.
how to slow down video??
By uglijimus in forum Video ConversionReplies: 4Last Post: 13th Nov 2009, 09:12 -
Can You Slow Down Video
By cobalt1254 in forum Newbie / General discussionsReplies: 4Last Post: 4th Apr 2009, 13:41 -
slow down video
By natty in forum Newbie / General discussionsReplies: 4Last Post: 19th Feb 2009, 01:37 -
Slow down .AVI video
By hcs in forum Video ConversionReplies: 1Last Post: 13th Jan 2009, 08:11 -
Need to slow video
By Jeikobu in forum MacReplies: 3Last Post: 11th Mar 2008, 09:05
