I've been using S2D for awhile to process bin/que files into DVDs. Now I'd like to make DVDs from movies I had already burnt to CDs (usually 2 or 3 SVCD discs, but some are VCDs). What steps do I do to get the best quality? Was there any magic performed by S2D when it extracted the MPGs from the bin/que files? If so I could recreate bin/cue files from the CDs, but that seems excessive.
Use isobuster...
Thanks, CB. I just downloaded ISObuster and tried it a bit. I also tried recreating the bin/cue with CDRwin (which I had used to burn it originally) and it doesn't take any longer than the ISObuster extraction. I feel more comfortable with then feeding the recreated bin files to S2D and letting VCDgear extract the MPGs. They are always a little smaller than the MPG on the CD so I guess it is 'massaging' them a little. I'm going to go that way for now unless something screws up.
Need help getting burnt in subtitles for video
By TheGasMaster4381 in forum Newbie / General discussionsReplies: 3Last Post: 18th Dec 2010, 17:04 -
How to rip the video from (S)VCD CDs or BIN/CUE images
By Baldrick in forum User guidesReplies: 45Last Post: 4th Aug 2010, 06:56 -
Burnt Disk Names
By wahsac in forum MacReplies: 1Last Post: 2nd Jan 2010, 18:49 -
playing burnt dvd's
By deadgirl in forum Newbie / General discussionsReplies: 4Last Post: 16th Oct 2008, 00:56 -
Removing burnt in subtitles
By Egat in forum SubtitleReplies: 0Last Post: 15th Aug 2007, 03:38
