I need to convert an avi, so i can burn it on just a regular cd-r and not a dvd, when i run ffmpegx and i drag my avi into one side, and select svcd on the other and click convert, it just goes "ding finished" am i not doing it right??? anything you can tell me will help!!!
Results 1 to 10 of 10
ok i think it is working now, maybe it just had something to do with the avi file i was trying to convert , so if i want to put an avi as an svcd and make it fit on the 700 or 800mb disc do i select svcd ffmpeg or svcd mpeg2enc?
it said" failed"
Mon Oct 24 21:55:57 CDT 2005
Input #0, yuv4mpegpipe, from 'pipe:':
Duration: N/A, bitrate: N/A
Stream #0.0: Video: rawvideo, yuv420p, 480x576, 25.00 fps
Output #0, rawvideo, to '/Users/adam/Documents/warez/Blair Witch Project I and II/The Blair Witch Project Beef_Stew_RG.avi.ff.mpv':
Stream #0.0: Video: mpeg2video, yuv420p, 480x576, 25.00 fps, q=2-20, 2500 kb/s
Stream mapping:
Stream #0.0 -> #0.0
bench: utime=1381.593s
video:1421123kB audio:0kB global headers:0kB muxing overhead 0.000000%
Computing levels...
The Blair Witch P --% done, ETA --:--:-- (batch 0% done, ETA 99:14:08)
The Blair Witch P 1% done, ETA 00:00:00 (batch 1% done, ETA 00:00:00)
The Blair Witch P 2% done, ETA 00:00:00 (batch 2% done, ETA 00:00:00)
The Blair Witch P 3% done, ETA 00:00:00 (batch 3% done, ETA 00:00:00)
The Blair Witch P 4% done, ETA 00:00:24 (batch 4% done, ETA 00:00:24)
The Blair Witch P 5% done, ETA 00:00:19 (batch 5% done, ETA 00:00:19)
The Blair Witch P 6% done, ETA 00:00:16 (batch 6% done, ETA 00:00:16)
The Blair Witch P 7% done, ETA 00:00:27 (batch 7% done, ETA 00:00:27)
The Blair Witch P 8% done, ETA 00:00:23 (batch 8% done, ETA 00:00:23)
The Blair Witch P 9% done, ETA 00:00:30 (batch 9% done, ETA 00:00:30)
The Blair Witch P 10% done, ETA 00:00:27 (batch 10% done, ETA 00:00:27)
The Blair Witch P 11% done, ETA 00:00:32 (batch 11% done, ETA 00:00:32)
The Blair Witch P 12% done, ETA 00:00:29 (batch 12% done, ETA 00:00:29)
The Blair Witch P 13% done, ETA 00:00:33 (batch 13% done, ETA 00:00:33)
The Blair Witch P 14% done, ETA 00:00:31 (batch 14% done, ETA 00:00:31)
The Blair Witch P 15% done, ETA 00:00:28 (batch 15% done, ETA 00:00:28)
The Blair Witch P 16% done, ETA 00:00:31 (batch 16% done, ETA 00:00:31)
The Blair Witch P 17% done, ETA 00:00:29 (batch 17% done, ETA 00:00:29)
The Blair Witch P 18% done, ETA 00:00:32 (batch 18% done, ETA 00:00:32)
The Blair Witch P 19% done, ETA 00:00:30 (batch 19% done, ETA 00:00:30)
The Blair Witch P 20% done, ETA 00:00:32 (batch 20% done, ETA 00:00:32)
The Blair Witch P 21% done, ETA 00:00:30 (batch 21% done, ETA 00:00:30)
The Blair Witch P 22% done, ETA 00:00:28 (batch 22% done, ETA 00:00:28)
The Blair Witch P 23% done, ETA 00:00:30 (batch 23% done, ETA 00:00:30)
The Blair Witch P 24% done, ETA 00:00:28 (batch 24% done, ETA 00:00:29)
The Blair Witch P 25% done, ETA 00:00:30 (batch 25% done, ETA 00:00:30)
The Blair Witch P 26% done, ETA 00:00:28 (batch 26% done, ETA 00:00:28)
The Blair Witch P 27% done, ETA 00:00:27 (batch 27% done, ETA 00:00:27)
The Blair Witch P 28% done, ETA 00:00:28 (batch 28% done, ETA 00:00:28)
The Blair Witch P 29% done, ETA 00:00:27 (batch 29% done, ETA 00:00:27)
The Blair Witch P 30% done, ETA 00:00:28 (batch 30% done, ETA 00:00:28)
The Blair Witch P 31% done, ETA 00:00:27 (batch 31% done, ETA 00:00:27)
The Blair Witch P 32% done, ETA 00:00:28 (batch 32% done, ETA 00:00:28)
The Blair Witch P 33% done, ETA 00:00:26 (batch 33% done, ETA 00:00:26)
The Blair Witch P 34% done, ETA 00:00:27 (batch 34% done, ETA 00:00:27)
The Blair Witch P 35% done, ETA 00:00:26 (batch 35% done, ETA 00:00:26)
The Blair Witch P 36% done, ETA 00:00:25 (batch 36% done, ETA 00:00:25)
The Blair Witch P 37% done, ETA 00:00:26 (batch 37% done, ETA 00:00:26)
The Blair Witch P 38% done, ETA 00:00:24 (batch 38% done, ETA 00:00:24)
The Blair Witch P 39% done, ETA 00:00:25 (batch 39% done, ETA 00:00:25)
The Blair Witch P 40% done, ETA 00:00:24 (batch 40% done, ETA 00:00:24)
The Blair Witch P 41% done, ETA 00:00:24 (batch 41% done, ETA 00:00:24)
The Blair Witch P 42% done, ETA 00:00:23 (batch 42% done, ETA 00:00:23)
The Blair Witch P 43% done, ETA 00:00:24 (batch 43% done, ETA 00:00:24)
The Blair Witch P 44% done, ETA 00:00:23 (batch 44% done, ETA 00:00:23)
The Blair Witch P 45% done, ETA 00:00:22 (batch 45% done, ETA 00:00:22)
The Blair Witch P 46% done, ETA 00:00:22 (batch 46% done, ETA 00:00:22)
The Blair Witch P 47% done, ETA 00:00:21 (batch 47% done, ETA 00:00:21)
The Blair Witch P 48% done, ETA 00:00:22 (batch 48% done, ETA 00:00:22)
The Blair Witch P 49% done, ETA 00:00:21 (batch 49% done, ETA 00:00:21)
The Blair Witch P 50% done, ETA 00:00:21 (batch 50% done, ETA 00:00:21)
The Blair Witch P 51% done, ETA 00:00:20 (batch 51% done, ETA 00:00:20)
The Blair Witch P 52% done, ETA 00:00:20 (batch 52% done, ETA 00:00:20)
The Blair Witch P 53% done, ETA 00:00:20 (batch 53% done, ETA 00:00:20)
The Blair Witch P 54% done, ETA 00:00:19 (batch 54% done, ETA 00:00:19)
The Blair Witch P 55% done, ETA 00:00:19 (batch 55% done, ETA 00:00:19)
The Blair Witch P 56% done, ETA 00:00:18 (batch 56% done, ETA 00:00:18)
The Blair Witch P 57% done, ETA 00:00:18 (batch 57% done, ETA 00:00:18)
The Blair Witch P 58% done, ETA 00:00:17 (batch 58% done, ETA 00:00:17)
The Blair Witch P 59% done, ETA 00:00:17 (batch 59% done, ETA 00:00:17)
The Blair Witch P 60% done, ETA 00:00:17 (batch 60% done, ETA 00:00:17)
The Blair Witch P 61% done, ETA 00:00:17 (batch 61% done, ETA 00:00:17)
The Blair Witch P 62% done, ETA 00:00:16 (batch 62% done, ETA 00:00:16)
The Blair Witch P 63% done, ETA 00:00:15 (batch 63% done, ETA 00:00:15)
The Blair Witch P 64% done, ETA 00:00:15 (batch 64% done, ETA 00:00:15)
The Blair Witch P 65% done, ETA 00:00:15 (batch 65% done, ETA 00:00:15)
The Blair Witch P 66% done, ETA 00:00:14 (batch 66% done, ETA 00:00:14)
The Blair Witch P 67% done, ETA 00:00:14 (batch 67% done, ETA 00:00:14)
The Blair Witch P 68% done, ETA 00:00:14 (batch 68% done, ETA 00:00:14)
The Blair Witch P 69% done, ETA 00:00:13 (batch 69% done, ETA 00:00:13)
The Blair Witch P 70% done, ETA 00:00:13 (batch 70% done, ETA 00:00:13)
The Blair Witch P 71% done, ETA 00:00:12 (batch 71% done, ETA 00:00:12)
The Blair Witch P 72% done, ETA 00:00:12 (batch 72% done, ETA 00:00:12)
The Blair Witch P 73% done, ETA 00:00:11 (batch 73% done, ETA 00:00:11)
The Blair Witch P 74% done, ETA 00:00:11 (batch 74% done, ETA 00:00:11)
The Blair Witch P 75% done, ETA 00:00:11 (batch 75% done, ETA 00:00:11)
The Blair Witch P 76% done, ETA 00:00:10 (batch 76% done, ETA 00:00:10)
The Blair Witch P 77% done, ETA 00:00:10 (batch 77% done, ETA 00:00:10)
The Blair Witch P 78% done, ETA 00:00:10 (batch 78% done, ETA 00:00:10)
The Blair Witch P 79% done, ETA 00:00:09 (batch 79% done, ETA 00:00:09)
The Blair Witch P 80% done, ETA 00:00:09 (batch 80% done, ETA 00:00:09)
The Blair Witch P 81% done, ETA 00:00:08 (batch 81% done, ETA 00:00:08)
The Blair Witch P 82% done, ETA 00:00:08 (batch 82% done, ETA 00:00:08)
The Blair Witch P 83% done, ETA 00:00:07 (batch 83% done, ETA 00:00:07)
The Blair Witch P 84% done, ETA 00:00:07 (batch 84% done, ETA 00:00:07)
The Blair Witch P 85% done, ETA 00:00:07 (batch 85% done, ETA 00:00:07)
The Blair Witch P 86% done, ETA 00:00:06 (batch 86% done, ETA 00:00:06)
The Blair Witch P 87% done, ETA 00:00:06 (batch 87% done, ETA 00:00:06)
The Blair Witch P 88% done, ETA 00:00:05 (batch 88% done, ETA 00:00:05)
The Blair Witch P 89% done, ETA 00:00:05 (batch 89% done, ETA 00:00:05)
The Blair Witch P 90% done, ETA 00:00:04 (batch 90% done, ETA 00:00:04)
The Blair Witch P 91% done, ETA 00:00:04 (batch 91% done, ETA 00:00:04)
The Blair Witch P 92% done, ETA 00:00:03 (batch 92% done, ETA 00:00:03)
The Blair Witch P 93% done, ETA 00:00:03 (batch 93% done, ETA 00:00:03)
The Blair Witch P 94% done, ETA 00:00:03 (batch 94% done, ETA 00:00:03)
The Blair Witch P 95% done, ETA 00:00:02 (batch 95% done, ETA 00:00:02)
The Blair Witch P 96% done, ETA 00:00:02 (batch 96% done, ETA 00:00:02)
The Blair Witch P 97% done, ETA 00:00:01 (batch 97% done, ETA 00:00:01)
The Blair Witch P 98% done, ETA 00:00:01 (batch 98% done, ETA 00:00:01)
The Blair Witch P 99% done, ETA 00:00:00 (batch 99% done, ETA 00:00:00)
The Blair Witch P 100% done, ETA 00:00:00 (batch 100% done, ETA 00:00:00)
Applying adjustment of 5.97dB to /Users/adam/Documents/warez/Blair Witch Project I and II/The Blair Witch Project Beef_Stew_RG.avi.ff.wav...
The Blair Witch P 2% done, ETA 00:00:49 (batch 2% done, ETA 00:00:49)
The Blair Witch P 3% done, ETA 00:00:32 (batch 3% done, ETA 00:00:32)
The Blair Witch P 5% done, ETA 00:00:38 (batch 5% done, ETA 00:00:38)
The Blair Witch P 6% done, ETA 00:00:47 (batch 6% done, ETA 00:00:47)
The Blair Witch P 7% done, ETA 00:00:40 (batch 7% done, ETA 00:00:40)
The Blair Witch P 8% done, ETA 00:00:46 (batch 8% done, ETA 00:00:46)
The Blair Witch P 9% done, ETA 00:00:51 (batch 9% done, ETA 00:00:51)
The Blair Witch P 10% done, ETA 00:00:54 (batch 10% done, ETA 00:00:54)
The Blair Witch P 11% done, ETA 00:00:57 (batch 11% done, ETA 00:00:57)
The Blair Witch P 12% done, ETA 00:00:59 (batch 12% done, ETA 00:00:59)
The Blair Witch P 13% done, ETA 00:00:54 (batch 13% done, ETA 00:00:54)
The Blair Witch P 14% done, ETA 00:00:55 (batch 14% done, ETA 00:00:55)
The Blair Witch P 15% done, ETA 00:00:57 (batch 15% done, ETA 00:00:57)
The Blair Witch P 16% done, ETA 00:00:58 (batch 16% done, ETA 00:00:58)
The Blair Witch P 17% done, ETA 00:00:59 (batch 17% done, ETA 00:00:59)
The Blair Witch P 18% done, ETA 00:00:55 (batch 18% done, ETA 00:00:55)
The Blair Witch P 19% done, ETA 00:00:55 (batch 19% done, ETA 00:00:55)
The Blair Witch P 20% done, ETA 00:00:56 (batch 20% done, ETA 00:00:56)
The Blair Witch P 21% done, ETA 00:00:56 (batch 21% done, ETA 00:00:56)
The Blair Witch P 22% done, ETA 00:00:57 (batch 22% done, ETA 00:00:57)
The Blair Witch P 23% done, ETA 00:00:57 (batch 23% done, ETA 00:00:57)
The Blair Witch P 24% done, ETA 00:00:57 (batch 24% done, ETA 00:00:57)
The Blair Witch P 25% done, ETA 00:00:57 (batch 25% done, ETA 00:00:57)
The Blair Witch P 26% done, ETA 00:00:57 (batch 26% done, ETA 00:00:57)
The Blair Witch P 27% done, ETA 00:00:57 (batch 27% done, ETA 00:00:57)
The Blair Witch P 28% done, ETA 00:00:54 (batch 28% done, ETA 00:00:54)
The Blair Witch P 29% done, ETA 00:00:54 (batch 29% done, ETA 00:00:54)
The Blair Witch P 30% done, ETA 00:00:54 (batch 30% done, ETA 00:00:54)
The Blair Witch P 31% done, ETA 00:00:53 (batch 31% done, ETA 00:00:53)
The Blair Witch P 32% done, ETA 00:00:53 (batch 32% done, ETA 00:00:53)
The Blair Witch P 33% done, ETA 00:00:53 (batch 33% done, ETA 00:00:53)
The Blair Witch P 34% done, ETA 00:00:52 (batch 34% done, ETA 00:00:52)
The Blair Witch P 35% done, ETA 00:00:52 (batch 35% done, ETA 00:00:52)
The Blair Witch P 36% done, ETA 00:00:50 (batch 36% done, ETA 00:00:50)
The Blair Witch P 37% done, ETA 00:00:49 (batch 37% done, ETA 00:00:49)
The Blair Witch P 38% done, ETA 00:00:51 (batch 38% done, ETA 00:00:51)
The Blair Witch P 39% done, ETA 00:00:50 (batch 39% done, ETA 00:00:50)
The Blair Witch P 40% done, ETA 00:00:49 (batch 40% done, ETA 00:00:49)
The Blair Witch P 41% done, ETA 00:00:47 (batch 41% done, ETA 00:00:47)
The Blair Witch P 42% done, ETA 00:00:47 (batch 42% done, ETA 00:00:47)
The Blair Witch P 43% done, ETA 00:00:46 (batch 43% done, ETA 00:00:46)
The Blair Witch P 44% done, ETA 00:00:46 (batch 44% done, ETA 00:00:46)
The Blair Witch P 45% done, ETA 00:00:45 (batch 45% done, ETA 00:00:45)
The Blair Witch P 46% done, ETA 00:00:45 (batch 46% done, ETA 00:00:45)
The Blair Witch P 47% done, ETA 00:00:43 (batch 47% done, ETA 00:00:43)
The Blair Witch P 48% done, ETA 00:00:42 (batch 48% done, ETA 00:00:42)
The Blair Witch P 49% done, ETA 00:00:42 (batch 49% done, ETA 00:00:42)
The Blair Witch P 50% done, ETA 00:00:41 (batch 50% done, ETA 00:00:41)
The Blair Witch P 51% done, ETA 00:00:40 (batch 51% done, ETA 00:00:40)
The Blair Witch P 52% done, ETA 00:00:40 (batch 52% done, ETA 00:00:40)
The Blair Witch P 53% done, ETA 00:00:39 (batch 53% done, ETA 00:00:39)
The Blair Witch P 54% done, ETA 00:00:38 (batch 54% done, ETA 00:00:38)
The Blair Witch P 55% done, ETA 00:00:37 (batch 55% done, ETA 00:00:37)
The Blair Witch P 56% done, ETA 00:00:36 (batch 56% done, ETA 00:00:36)
The Blair Witch P 57% done, ETA 00:00:35 (batch 57% done, ETA 00:00:35)
The Blair Witch P 58% done, ETA 00:00:35 (batch 58% done, ETA 00:00:35)
The Blair Witch P 59% done, ETA 00:00:33 (batch 59% done, ETA 00:00:33)
The Blair Witch P 60% done, ETA 00:00:33 (batch 60% done, ETA 00:00:33)
The Blair Witch P 61% done, ETA 00:00:32 (batch 61% done, ETA 00:00:32)
The Blair Witch P 62% done, ETA 00:00:31 (batch 62% done, ETA 00:00:31)
The Blair Witch P 63% done, ETA 00:00:31 (batch 63% done, ETA 00:00:31)
The Blair Witch P 64% done, ETA 00:00:29 (batch 64% done, ETA 00:00:29)
The Blair Witch P 65% done, ETA 00:00:29 (batch 65% done, ETA 00:00:29)
The Blair Witch P 66% done, ETA 00:00:28 (batch 66% done, ETA 00:00:28)
The Blair Witch P 67% done, ETA 00:00:27 (batch 67% done, ETA 00:00:27)
The Blair Witch P 68% done, ETA 00:00:26 (batch 68% done, ETA 00:00:26)
The Blair Witch P 69% done, ETA 00:00:26 (batch 69% done, ETA 00:00:26)
The Blair Witch P 70% done, ETA 00:00:24 (batch 70% done, ETA 00:00:24)
The Blair Witch P 71% done, ETA 00:00:24 (batch 71% done, ETA 00:00:24)
The Blair Witch P 72% done, ETA 00:00:23 (batch 72% done, ETA 00:00:23)
The Blair Witch P 73% done, ETA 00:00:22 (batch 73% done, ETA 00:00:22)
The Blair Witch P 74% done, ETA 00:00:21 (batch 74% done, ETA 00:00:21)
The Blair Witch P 75% done, ETA 00:00:20 (batch 75% done, ETA 00:00:20)
The Blair Witch P 76% done, ETA 00:00:20 (batch 76% done, ETA 00:00:20)
The Blair Witch P 77% done, ETA 00:00:19 (batch 77% done, ETA 00:00:19)
The Blair Witch P 78% done, ETA 00:00:18 (batch 78% done, ETA 00:00:18)
The Blair Witch P 79% done, ETA 00:00:17 (batch 79% done, ETA 00:00:17)
The Blair Witch P 80% done, ETA 00:00:16 (batch 80% done, ETA 00:00:16)
The Blair Witch P 81% done, ETA 00:00:15 (batch 81% done, ETA 00:00:15)
The Blair Witch P 82% done, ETA 00:00:15 (batch 82% done, ETA 00:00:15)
The Blair Witch P 83% done, ETA 00:00:14 (batch 83% done, ETA 00:00:14)
The Blair Witch P 84% done, ETA 00:00:13 (batch 84% done, ETA 00:00:13)
The Blair Witch P 85% done, ETA 00:00:12 (batch 85% done, ETA 00:00:12)
The Blair Witch P 86% done, ETA 00:00:11 (batch 86% done, ETA 00:00:11)
The Blair Witch P 87% done, ETA 00:00:10 (batch 87% done, ETA 00:00:10)
The Blair Witch P 88% done, ETA 00:00:10 (batch 88% done, ETA 00:00:10)
The Blair Witch P 89% done, ETA 00:00:09 (batch 89% done, ETA 00:00:09)
The Blair Witch P 90% done, ETA 00:00:08 (batch 90% done, ETA 00:00:08)
The Blair Witch P 91% done, ETA 00:00:07 (batch 91% done, ETA 00:00:07)
The Blair Witch P 92% done, ETA 00:00:06 (batch 92% done, ETA 00:00:06)
The Blair Witch P 93% done, ETA 00:00:06 (batch 93% done, ETA 00:00:06)
The Blair Witch P 94% done, ETA 00:00:05 (batch 94% done, ETA 00:00:05)
The Blair Witch P 95% done, ETA 00:00:04 (batch 95% done, ETA 00:00:04)
The Blair Witch P 96% done, ETA 00:00:03 (batch 96% done, ETA 00:00:03)
The Blair Witch P 97% done, ETA 00:00:02 (batch 97% done, ETA 00:00:02)
The Blair Witch P 98% done, ETA 00:00:02 (batch 98% done, ETA 00:00:02)
The Blair Witch P 99% done, ETA 00:00:01 (batch 99% done, ETA 00:00:01)
Input #0, wav, from '/Users/adam/Documents/warez/Blair Witch Project I and II/The Blair Witch Project Beef_Stew_RG.avi.ff.wav':
Duration: 01:17:36.9, start: 0.000000, bitrate: 1535 kb/s
Stream #0.0: Audio: pcm_s16le, 48000 Hz, stereo, 1536 kb/s
Output #0, mp2, to '/Users/adam/Documents/warez/Blair Witch Project I and II/The Blair Witch Project Beef_Stew_RG.avi.ff.mp2':
Stream #0.0: Audio: mp2, 44100 Hz, stereo, 224 kb/s
Stream mapping:
Stream #0.0 -> #0.0
video:0kB audio:127337kB global headers:0kB muxing overhead 0.000000%
(Super) VideoCD xml description created successfully as `The.xml'
**ERROR: could not stat() file `The': No such file or directory
(Super) VideoCD xml description created successfully as `Blair.xml'
**ERROR: could not stat() file `Blair': No such file or directory
(Super) VideoCD xml description created successfully as `Witch.xml'
**ERROR: could not stat() file `Witch': No such file or directory
(Super) VideoCD xml description created successfully as `Project.xml'
**ERROR: could not stat() file `Project': No such file or directory
(Super) VideoCD xml description created successfully as `Beef_Stew_RG.avi.xml'
**ERROR: could not stat() file `Beef_Stew_RG.avi': No such file or directory
(Super) VideoCD xml description created successfully as `Beef_Stew_RG.avi.ff-1.mpg.xml'
**ERROR: could not stat() file `Beef_Stew_RG.avi.ff-1.mpg': No such file or directory
(Super) VideoCD xml description created successfully as `Beef_Stew_RG.avi.ff-2.mpg.xml'
**ERROR: could not stat() file `Beef_Stew_RG.avi.ff-2.mpg': No such file or directory
(Super) VideoCD xml description created successfully as `II.xml'
**ERROR: could not stat() file `II': No such file or directory
error while parsing command line - try --help
**ERROR: error while parsing command line - try --help
(Super) VideoCD xml description created successfully as `Book.xml'
rm: illegal option -- .
usage: rm [-f | -i] [-dPRrvW] file ...
unlink file
**ERROR: could not stat() file `Book': No such file or directory
(Super) VideoCD xml description created successfully as `of.xml'
**ERROR: could not stat() file `of': No such file or directory
(Super) VideoCD xml description created successfully as `Shadows.xml'
**ERROR: could not stat() file `Shadows': No such file or directory
Encoding completed on Tue Oct 25 00:09:33 CDT 2005
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
Tue Oct 25 13:49:07 CDT 2005
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
INFO: [yuvscaler] input: frame size: 480x576 pixels (414720 bytes)
INFO: [yuvscaler] input: frame rate: 25/1 fps (~25.000000)
INFO: [yuvscaler] input: interlace: none/progressive
INFO: [yuvscaler] input: sample aspect ratio: 1:1
INFO: [yuvscaler] from 480x576, take 480x576+0+0, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] scale to 480x576, 480x576 being displayed, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] Scaling uses the RESAMPLE algorithm,
INFO: [yuvscaler] without line switching
INFO: [yuvscaler] without time forwarding
INFO: [yuvscaler] Without luminance correction
INFO: [yuvscaler] Without chrominance correction
INFO: [yuvscaler] frame rate: 25.000 fps
INFO: [yuvscaler] Scaling ratio for width is 1 to 1
INFO: [yuvscaler] and is 1 to 1 for height
INFO: [yuvscaler] Specific downscaling routing number 4
INFO: [yuvscaler] output: frame size: 480x576 pixels (414720 bytes)
INFO: [yuvscaler] output: frame rate: 25/1 fps (~25.000000)
INFO: [yuvscaler] output: interlace: none/progressive
INFO: [yuvscaler] output: sample aspect ratio: 1:1
INFO: [mpeg2enc] SVCD standard settings selected
INFO: [mpeg2enc] Selecting SVCD output profile
INFO: [mpeg2enc] Assuming norm PAL
++ WARN: [mpeg2enc] Generating dummy SVCD scan-data offsets to be filled in by "vcdimager"
INFO: [mpeg2enc] Encoding MPEG-2 video to /Users/adam/Documents/warez/Blair Witch Project I and II/blairwitch1.avi.ff.m2v
INFO: [mpeg2enc] Horizontal size: 480 pel
INFO: [mpeg2enc] Vertical size: 576 pel
INFO: [mpeg2enc] Aspect ratio code: 2 = 4:3 display
INFO: [mpeg2enc] Frame rate code: 3 = 25.0 (PAL/SECAM VIDEO / converted FILM)
INFO: [mpeg2enc] Bitrate: 2500 KBit/s
INFO: [mpeg2enc] Quality factor: 6 (Quantisation = 6) (1=best, 31=worst)
INFO: [mpeg2enc] Field order for input: none/progressive
INFO: [mpeg2enc] New Sequence every 9999 Mbytes
INFO: [mpeg2enc] Assuming non-video stream of 230 Kbps
INFO: [mpeg2enc] Search radius: 16
INFO: [mpeg2enc] GOP SIZE RANGE 9 TO 15
INFO: [mpeg2enc] Setting colour/gamma parameters to "PAL B/G"
INFO: [mpeg2enc] Progressive format frames = 1
INFO: [mpeg2enc] Using default unmodified quantization matrices
INFO: [mpeg2enc] Buffering 39 frames
INFO: [mpeg2enc] SETTING AltiVec for QUANTIZER!
INFO: [mpeg2enc] SETTING AltiVec for MOTION!
INFO: [mpeg2enc] SETTING AltiVec for TRANSFORM!
INFO: [mpeg2enc] SETTING AltiVec for PREDICTION!
INFO: [yuvscaler] End of stream!
INFO: [yuvscaler] Normal exit: end of stream with frame number 116423!
INFO: [mpeg2enc] Guesstimated final muxed size = 1430604874
Computing levels...
blairwitch1.avi.f --% done, ETA --:--:-- (batch 0% done, ETA 99:14:08)
blairwitch1.avi.f 1% done, ETA 00:00:00 (batch 1% done, ETA 00:00:00)
blairwitch1.avi.f 2% done, ETA 00:00:49 (batch 2% done, ETA 00:00:49)
blairwitch1.avi.f 3% done, ETA 00:00:32 (batch 3% done, ETA 00:00:32)
blairwitch1.avi.f 4% done, ETA 00:00:48 (batch 4% done, ETA 00:00:48)
blairwitch1.avi.f 5% done, ETA 00:00:38 (batch 5% done, ETA 00:00:38)
blairwitch1.avi.f 6% done, ETA 00:00:47 (batch 6% done, ETA 00:00:47)
blairwitch1.avi.f 7% done, ETA 00:00:40 (batch 7% done, ETA 00:00:40)
blairwitch1.avi.f 8% done, ETA 00:00:46 (batch 8% done, ETA 00:00:46)
blairwitch1.avi.f 9% done, ETA 00:00:51 (batch 9% done, ETA 00:00:51)
blairwitch1.avi.f 10% done, ETA 00:00:54 (batch 10% done, ETA 00:00:54)
blairwitch1.avi.f 11% done, ETA 00:00:57 (batch 11% done, ETA 00:00:57)
blairwitch1.avi.f 12% done, ETA 00:00:51 (batch 12% done, ETA 00:00:51)
blairwitch1.avi.f 13% done, ETA 00:00:54 (batch 13% done, ETA 00:00:54)
blairwitch1.avi.f 14% done, ETA 00:00:49 (batch 14% done, ETA 00:00:49)
blairwitch1.avi.f 15% done, ETA 00:00:51 (batch 15% done, ETA 00:00:51)
blairwitch1.avi.f 16% done, ETA 00:00:47 (batch 16% done, ETA 00:00:47)
blairwitch1.avi.f 17% done, ETA 00:00:49 (batch 17% done, ETA 00:00:49)
blairwitch1.avi.f 18% done, ETA 00:00:50 (batch 18% done, ETA 00:00:50)
blairwitch1.avi.f 19% done, ETA 00:00:47 (batch 19% done, ETA 00:00:47)
blairwitch1.avi.f 20% done, ETA 00:00:48 (batch 20% done, ETA 00:00:48)
blairwitch1.avi.f 21% done, ETA 00:00:45 (batch 21% done, ETA 00:00:45)
blairwitch1.avi.f 22% done, ETA 00:00:46 (batch 22% done, ETA 00:00:46)
blairwitch1.avi.f 23% done, ETA 00:00:47 (batch 23% done, ETA 00:00:47)
blairwitch1.avi.f 24% done, ETA 00:00:44 (batch 24% done, ETA 00:00:44)
blairwitch1.avi.f 25% done, ETA 00:00:45 (batch 25% done, ETA 00:00:45)
blairwitch1.avi.f 26% done, ETA 00:00:46 (batch 26% done, ETA 00:00:46)
blairwitch1.avi.f 27% done, ETA 00:00:43 (batch 27% done, ETA 00:00:43)
blairwitch1.avi.f 28% done, ETA 00:00:44 (batch 28% done, ETA 00:00:44)
blairwitch1.avi.f 29% done, ETA 00:00:42 (batch 29% done, ETA 00:00:42)
blairwitch1.avi.f 30% done, ETA 00:00:42 (batch 30% done, ETA 00:00:42)
blairwitch1.avi.f 31% done, ETA 00:00:40 (batch 31% done, ETA 00:00:40)
blairwitch1.avi.f 32% done, ETA 00:00:40 (batch 32% done, ETA 00:00:40)
blairwitch1.avi.f 33% done, ETA 00:00:41 (batch 33% done, ETA 00:00:41)
blairwitch1.avi.f 34% done, ETA 00:00:39 (batch 34% done, ETA 00:00:39)
blairwitch1.avi.f 35% done, ETA 00:00:39 (batch 35% done, ETA 00:00:39)
blairwitch1.avi.f 36% done, ETA 00:00:37 (batch 36% done, ETA 00:00:37)
blairwitch1.avi.f 37% done, ETA 00:00:37 (batch 37% done, ETA 00:00:37)
blairwitch1.avi.f 38% done, ETA 00:00:38 (batch 38% done, ETA 00:00:38)
blairwitch1.avi.f 39% done, ETA 00:00:36 (batch 39% done, ETA 00:00:36)
blairwitch1.avi.f 40% done, ETA 00:00:36 (batch 40% done, ETA 00:00:36)
blairwitch1.avi.f 41% done, ETA 00:00:35 (batch 41% done, ETA 00:00:35)
blairwitch1.avi.f 42% done, ETA 00:00:35 (batch 42% done, ETA 00:00:35)
blairwitch1.avi.f 43% done, ETA 00:00:34 (batch 43% done, ETA 00:00:34)
blairwitch1.avi.f 44% done, ETA 00:00:33 (batch 44% done, ETA 00:00:33)
blairwitch1.avi.f 45% done, ETA 00:00:33 (batch 45% done, ETA 00:00:33)
blairwitch1.avi.f 46% done, ETA 00:00:33 (batch 46% done, ETA 00:00:33)
blairwitch1.avi.f 47% done, ETA 00:00:32 (batch 47% done, ETA 00:00:32)
blairwitch1.avi.f 48% done, ETA 00:00:31 (batch 48% done, ETA 00:00:31)
blairwitch1.avi.f 49% done, ETA 00:00:30 (batch 49% done, ETA 00:00:30)
blairwitch1.avi.f 50% done, ETA 00:00:30 (batch 50% done, ETA 00:00:30)
blairwitch1.avi.f 51% done, ETA 00:00:31 (batch 51% done, ETA 00:00:31)
blairwitch1.avi.f 52% done, ETA 00:00:30 (batch 52% done, ETA 00:00:30)
blairwitch1.avi.f 53% done, ETA 00:00:29 (batch 53% done, ETA 00:00:29)
blairwitch1.avi.f 54% done, ETA 00:00:29 (batch 54% done, ETA 00:00:29)
blairwitch1.avi.f 55% done, ETA 00:00:28 (batch 55% done, ETA 00:00:28)
blairwitch1.avi.f 56% done, ETA 00:00:27 (batch 56% done, ETA 00:00:27)
blairwitch1.avi.f 57% done, ETA 00:00:27 (batch 57% done, ETA 00:00:27)
blairwitch1.avi.f 58% done, ETA 00:00:26 (batch 58% done, ETA 00:00:26)
blairwitch1.avi.f 59% done, ETA 00:00:26 (batch 59% done, ETA 00:00:26)
blairwitch1.avi.f 60% done, ETA 00:00:25 (batch 60% done, ETA 00:00:25)
blairwitch1.avi.f 61% done, ETA 00:00:24 (batch 61% done, ETA 00:00:24)
blairwitch1.avi.f 62% done, ETA 00:00:24 (batch 62% done, ETA 00:00:24)
blairwitch1.avi.f 63% done, ETA 00:00:23 (batch 63% done, ETA 00:00:23)
blairwitch1.avi.f 64% done, ETA 00:00:22 (batch 64% done, ETA 00:00:22)
blairwitch1.avi.f 65% done, ETA 00:00:22 (batch 65% done, ETA 00:00:22)
blairwitch1.avi.f 66% done, ETA 00:00:21 (batch 66% done, ETA 00:00:21)
blairwitch1.avi.f 67% done, ETA 00:00:21 (batch 67% done, ETA 00:00:21)
blairwitch1.avi.f 68% done, ETA 00:00:20 (batch 68% done, ETA 00:00:20)
blairwitch1.avi.f 69% done, ETA 00:00:19 (batch 69% done, ETA 00:00:19)
blairwitch1.avi.f 70% done, ETA 00:00:19 (batch 70% done, ETA 00:00:19)
blairwitch1.avi.f 71% done, ETA 00:00:18 (batch 71% done, ETA 00:00:18)
blairwitch1.avi.f 72% done, ETA 00:00:17 (batch 72% done, ETA 00:00:18)
blairwitch1.avi.f 73% done, ETA 00:00:17 (batch 73% done, ETA 00:00:17)
blairwitch1.avi.f 74% done, ETA 00:00:16 (batch 74% done, ETA 00:00:16)
blairwitch1.avi.f 75% done, ETA 00:00:16 (batch 75% done, ETA 00:00:16)
blairwitch1.avi.f 76% done, ETA 00:00:15 (batch 76% done, ETA 00:00:15)
blairwitch1.avi.f 77% done, ETA 00:00:14 (batch 77% done, ETA 00:00:14)
blairwitch1.avi.f 78% done, ETA 00:00:14 (batch 78% done, ETA 00:00:14)
blairwitch1.avi.f 79% done, ETA 00:00:13 (batch 79% done, ETA 00:00:13)
blairwitch1.avi.f 80% done, ETA 00:00:13 (batch 80% done, ETA 00:00:13)
blairwitch1.avi.f 81% done, ETA 00:00:12 (batch 81% done, ETA 00:00:12)
blairwitch1.avi.f 82% done, ETA 00:00:11 (batch 82% done, ETA 00:00:11)
blairwitch1.avi.f 83% done, ETA 00:00:11 (batch 83% done, ETA 00:00:11)
blairwitch1.avi.f 84% done, ETA 00:00:10 (batch 84% done, ETA 00:00:10)
blairwitch1.avi.f 85% done, ETA 00:00:09 (batch 85% done, ETA 00:00:09)
blairwitch1.avi.f 86% done, ETA 00:00:09 (batch 86% done, ETA 00:00:09)
blairwitch1.avi.f 87% done, ETA 00:00:08 (batch 87% done, ETA 00:00:08)
blairwitch1.avi.f 88% done, ETA 00:00:07 (batch 88% done, ETA 00:00:07)
blairwitch1.avi.f 89% done, ETA 00:00:07 (batch 89% done, ETA 00:00:07)
blairwitch1.avi.f 90% done, ETA 00:00:06 (batch 90% done, ETA 00:00:06)
blairwitch1.avi.f 91% done, ETA 00:00:06 (batch 91% done, ETA 00:00:06)
blairwitch1.avi.f 92% done, ETA 00:00:05 (batch 92% done, ETA 00:00:05)
blairwitch1.avi.f 93% done, ETA 00:00:04 (batch 93% done, ETA 00:00:04)
blairwitch1.avi.f 94% done, ETA 00:00:04 (batch 94% done, ETA 00:00:04)
blairwitch1.avi.f 95% done, ETA 00:00:03 (batch 95% done, ETA 00:00:03)
blairwitch1.avi.f 96% done, ETA 00:00:02 (batch 96% done, ETA 00:00:02)
blairwitch1.avi.f 97% done, ETA 00:00:02 (batch 97% done, ETA 00:00:02)
blairwitch1.avi.f 98% done, ETA 00:00:01 (batch 98% done, ETA 00:00:01)
blairwitch1.avi.f 99% done, ETA 00:00:01 (batch 99% done, ETA 00:00:01)
blairwitch1.avi.f 100% done, ETA 00:00:00 (batch 100% done, ETA 00:00:00)
Applying adjustment of 5.97dB to /Users/adam/Documents/warez/Blair Witch Project I and II/blairwitch1.avi.ff.wav...
blairwitch1.avi.f 2% done, ETA 00:00:00 (batch 2% done, ETA 00:00:00)
blairwitch1.avi.f 7% done, ETA 00:00:53 (batch 7% done, ETA 00:00:53)
blairwitch1.avi.f 8% done, ETA 00:00:57 (batch 8% done, ETA 00:00:57)
blairwitch1.avi.f 9% done, ETA 00:01:01 (batch 9% done, ETA 00:01:01)
blairwitch1.avi.f 12% done, ETA 00:00:59 (batch 12% done, ETA 00:00:59)
blairwitch1.avi.f 14% done, ETA 00:01:01 (batch 14% done, ETA 00:01:01)
blairwitch1.avi.f 15% done, ETA 00:01:02 (batch 15% done, ETA 00:01:02)
blairwitch1.avi.f 16% done, ETA 00:00:58 (batch 16% done, ETA 00:00:58)
blairwitch1.avi.f 17% done, ETA 00:00:59 (batch 17% done, ETA 00:00:59)
blairwitch1.avi.f 18% done, ETA 00:00:59 (batch 18% done, ETA 00:00:59)
blairwitch1.avi.f 19% done, ETA 00:00:55 (batch 19% done, ETA 00:00:55)
blairwitch1.avi.f 20% done, ETA 00:00:56 (batch 20% done, ETA 00:00:56)
blairwitch1.avi.f 21% done, ETA 00:00:56 (batch 21% done, ETA 00:00:56)
blairwitch1.avi.f 22% done, ETA 00:00:57 (batch 22% done, ETA 00:00:57)
blairwitch1.avi.f 23% done, ETA 00:00:57 (batch 23% done, ETA 00:00:57)
blairwitch1.avi.f 24% done, ETA 00:00:57 (batch 24% done, ETA 00:00:57)
blairwitch1.avi.f 25% done, ETA 00:00:54 (batch 25% done, ETA 00:00:54)
blairwitch1.avi.f 26% done, ETA 00:00:54 (batch 26% done, ETA 00:00:54)
blairwitch1.avi.f 27% done, ETA 00:00:54 (batch 27% done, ETA 00:00:54)
blairwitch1.avi.f 28% done, ETA 00:00:54 (batch 28% done, ETA 00:00:54)
blairwitch1.avi.f 29% done, ETA 00:00:54 (batch 29% done, ETA 00:00:54)
blairwitch1.avi.f 30% done, ETA 00:00:54 (batch 30% done, ETA 00:00:54)
blairwitch1.avi.f 31% done, ETA 00:00:51 (batch 31% done, ETA 00:00:51)
blairwitch1.avi.f 32% done, ETA 00:00:51 (batch 32% done, ETA 00:00:51)
blairwitch1.avi.f 33% done, ETA 00:00:51 (batch 33% done, ETA 00:00:51)
blairwitch1.avi.f 34% done, ETA 00:00:50 (batch 34% done, ETA 00:00:50)
blairwitch1.avi.f 35% done, ETA 00:00:50 (batch 35% done, ETA 00:00:50)
blairwitch1.avi.f 36% done, ETA 00:00:50 (batch 36% done, ETA 00:00:50)
blairwitch1.avi.f 37% done, ETA 00:00:48 (batch 37% done, ETA 00:00:48)
blairwitch1.avi.f 38% done, ETA 00:00:47 (batch 38% done, ETA 00:00:47)
blairwitch1.avi.f 39% done, ETA 00:00:47 (batch 39% done, ETA 00:00:47)
blairwitch1.avi.f 40% done, ETA 00:00:46 (batch 40% done, ETA 00:00:46)
blairwitch1.avi.f 41% done, ETA 00:00:46 (batch 41% done, ETA 00:00:46)
blairwitch1.avi.f 42% done, ETA 00:00:44 (batch 42% done, ETA 00:00:44)
blairwitch1.avi.f 43% done, ETA 00:00:44 (batch 43% done, ETA 00:00:44)
blairwitch1.avi.f 44% done, ETA 00:00:43 (batch 44% done, ETA 00:00:43)
blairwitch1.avi.f 45% done, ETA 00:00:43 (batch 45% done, ETA 00:00:43)
blairwitch1.avi.f 46% done, ETA 00:00:42 (batch 46% done, ETA 00:00:42)
blairwitch1.avi.f 47% done, ETA 00:00:41 (batch 47% done, ETA 00:00:41)
blairwitch1.avi.f 48% done, ETA 00:00:40 (batch 48% done, ETA 00:00:40)
blairwitch1.avi.f 49% done, ETA 00:00:40 (batch 49% done, ETA 00:00:40)
blairwitch1.avi.f 50% done, ETA 00:00:39 (batch 50% done, ETA 00:00:39)
blairwitch1.avi.f 51% done, ETA 00:00:37 (batch 51% done, ETA 00:00:37)
blairwitch1.avi.f 52% done, ETA 00:00:37 (batch 52% done, ETA 00:00:37)
blairwitch1.avi.f 53% done, ETA 00:00:36 (batch 53% done, ETA 00:00:36)
blairwitch1.avi.f 54% done, ETA 00:00:36 (batch 54% done, ETA 00:00:36)
blairwitch1.avi.f 55% done, ETA 00:00:34 (batch 55% done, ETA 00:00:34)
blairwitch1.avi.f 56% done, ETA 00:00:34 (batch 56% done, ETA 00:00:34)
blairwitch1.avi.f 57% done, ETA 00:00:33 (batch 57% done, ETA 00:00:33)
blairwitch1.avi.f 58% done, ETA 00:00:33 (batch 58% done, ETA 00:00:33)
blairwitch1.avi.f 59% done, ETA 00:00:32 (batch 59% done, ETA 00:00:32)
blairwitch1.avi.f 60% done, ETA 00:00:31 (batch 60% done, ETA 00:00:31)
blairwitch1.avi.f 61% done, ETA 00:00:30 (batch 61% done, ETA 00:00:30)
blairwitch1.avi.f 62% done, ETA 00:00:29 (batch 62% done, ETA 00:00:29)
blairwitch1.avi.f 63% done, ETA 00:00:29 (batch 63% done, ETA 00:00:29)
blairwitch1.avi.f 64% done, ETA 00:00:28 (batch 64% done, ETA 00:00:28)
blairwitch1.avi.f 65% done, ETA 00:00:27 (batch 65% done, ETA 00:00:27)
blairwitch1.avi.f 66% done, ETA 00:00:26 (batch 66% done, ETA 00:00:26)
blairwitch1.avi.f 67% done, ETA 00:00:26 (batch 67% done, ETA 00:00:26)
blairwitch1.avi.f 68% done, ETA 00:00:25 (batch 68% done, ETA 00:00:25)
blairwitch1.avi.f 69% done, ETA 00:00:24 (batch 69% done, ETA 00:00:24)
blairwitch1.avi.f 70% done, ETA 00:00:23 (batch 70% done, ETA 00:00:23)
blairwitch1.avi.f 71% done, ETA 00:00:22 (batch 71% done, ETA 00:00:22)
blairwitch1.avi.f 72% done, ETA 00:00:22 (batch 72% done, ETA 00:00:22)
blairwitch1.avi.f 73% done, ETA 00:00:21 (batch 73% done, ETA 00:00:21)
blairwitch1.avi.f 74% done, ETA 00:00:20 (batch 74% done, ETA 00:00:20)
blairwitch1.avi.f 75% done, ETA 00:00:19 (batch 75% done, ETA 00:00:19)
blairwitch1.avi.f 76% done, ETA 00:00:19 (batch 76% done, ETA 00:00:19)
blairwitch1.avi.f 77% done, ETA 00:00:18 (batch 77% done, ETA 00:00:18)
blairwitch1.avi.f 78% done, ETA 00:00:17 (batch 78% done, ETA 00:00:17)
blairwitch1.avi.f 79% done, ETA 00:00:16 (batch 79% done, ETA 00:00:16)
blairwitch1.avi.f 80% done, ETA 00:00:15 (batch 80% done, ETA 00:00:16)
blairwitch1.avi.f 81% done, ETA 00:00:15 (batch 81% done, ETA 00:00:15)
blairwitch1.avi.f 82% done, ETA 00:00:14 (batch 82% done, ETA 00:00:14)
blairwitch1.avi.f 83% done, ETA 00:00:13 (batch 83% done, ETA 00:00:13)
blairwitch1.avi.f 84% done, ETA 00:00:12 (batch 84% done, ETA 00:00:12)
blairwitch1.avi.f 85% done, ETA 00:00:12 (batch 85% done, ETA 00:00:12)
blairwitch1.avi.f 86% done, ETA 00:00:11 (batch 86% done, ETA 00:00:11)
blairwitch1.avi.f 87% done, ETA 00:00:10 (batch 87% done, ETA 00:00:10)
blairwitch1.avi.f 88% done, ETA 00:00:09 (batch 88% done, ETA 00:00:09)
blairwitch1.avi.f 89% done, ETA 00:00:09 (batch 89% done, ETA 00:00:09)
blairwitch1.avi.f 90% done, ETA 00:00:08 (batch 90% done, ETA 00:00:08)
blairwitch1.avi.f 91% done, ETA 00:00:07 (batch 91% done, ETA 00:00:07)
blairwitch1.avi.f 92% done, ETA 00:00:06 (batch 92% done, ETA 00:00:06)
blairwitch1.avi.f 93% done, ETA 00:00:05 (batch 93% done, ETA 00:00:05)
blairwitch1.avi.f 94% done, ETA 00:00:05 (batch 94% done, ETA 00:00:05)
blairwitch1.avi.f 95% done, ETA 00:00:04 (batch 95% done, ETA 00:00:04)
blairwitch1.avi.f 96% done, ETA 00:00:03 (batch 96% done, ETA 00:00:03)
blairwitch1.avi.f 98% done, ETA 00:00:02 (batch 98% done, ETA 00:00:02)
ffmpeg version CVS, build 3211265, Copyright (c) 2000-2004 Fabrice Bellard
configuration: --enable-mp3lame --enable-gpl --disable-vhook --enable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-amr_wb --enable-pthreads --enable-x264
built on Aug 14 2005 14:46:34, gcc: 3.3 20030304 (Apple Computer, Inc. build 1666)
Input #0, wav, from '/Users/adam/Documents/warez/Blair Witch Project I and II/blairwitch1.avi.ff.wav':
Output #0, mp2, to '/Users/adam/Documents/warez/Blair Witch Project I and II/blairwitch1.avi.ff.mp2':
Stream mapping:
Stream #0.0 -> #0.0
Press [q] to stop encoding
size= 389kB time=14.2 bitrate= 224.0kbits/s
size= 859kB time=31.4 bitrate= 224.0kbits/s
size= 1364kB time=49.9 bitrate= 224.0kbits/s
size= 1774kB time=64.9 bitrate= 224.0kbits/s
size= 2260kB time=82.7 bitrate= 224.0kbits/s
size= 2771kB time=101.4 bitrate= 224.0kbits/s
size= 3268kB time=119.5 bitrate= 224.0kbits/s
size= 3621kB time=132.4 bitrate= 224.0kbits/s
size= 4097kB time=149.8 bitrate= 224.0kbits/s
size= 4495kB time=164.4 bitrate= 224.0kbits/s
size= 4891kB time=178.9 bitrate= 224.0kbits/s
size= 5357kB time=195.9 bitrate= 224.0kbits/s
size= 5839kB time=213.5 bitrate= 224.0kbits/s
size= 6332kB time=231.6 bitrate= 224.0kbits/s
size= 6738kB time=246.4 bitrate= 224.0kbits/s
size= 7226kB time=264.3 bitrate= 224.0kbits/s
size= 7726kB time=282.5 bitrate= 224.0kbits/s
size= 8091kB time=295.9 bitrate= 224.0kbits/s
size= 8477kB time=310.0 bitrate= 224.0kbits/s
size= 8948kB time=327.2 bitrate= 224.0kbits/s
size= 9454kB time=345.8 bitrate= 224.0kbits/s
size= 9846kB time=360.1 bitrate= 224.0kbits/s
size= 10366kB time=379.1 bitrate= 224.0kbits/s
size= 10845kB time=396.6 bitrate= 224.0kbits/s
size= 11278kB time=412.4 bitrate= 224.0kbits/s
size= 11740kB time=429.3 bitrate= 224.0kbits/s
size= 12242kB time=447.7 bitrate= 224.0kbits/s
size= 12588kB time=460.4 bitrate= 224.0kbits/s
size= 12921kB time=472.6 bitrate= 224.0kbits/s
size= 13360kB time=488.6 bitrate= 224.0kbits/s
size= 13883kB time=507.7 bitrate= 224.0kbits/s
size= 14344kB time=524.6 bitrate= 224.0kbits/s
size= 14874kB time=544.0 bitrate= 224.0kbits/s
size= 15316kB time=560.1 bitrate= 224.0kbits/s
size= 15876kB time=580.6 bitrate= 224.0kbits/s
size= 16239kB time=593.9 bitrate= 224.0kbits/s
size= 16771kB time=613.3 bitrate= 224.0kbits/s
size= 17080kB time=624.6 bitrate= 224.0kbits/s
size= 17585kB time=643.1 bitrate= 224.0kbits/s
size= 18029kB time=659.3 bitrate= 224.0kbits/s
size= 18599kB time=680.2 bitrate= 224.0kbits/s
size= 19061kB time=697.1 bitrate= 224.0kbits/s
size= 19510kB time=713.5 bitrate= 224.0kbits/s
size= 19930kB time=728.9 bitrate= 224.0kbits/s
size= 20486kB time=749.2 bitrate= 224.0kbits/s
size= 20910kB time=764.7 bitrate= 224.0kbits/s
size= 21254kB time=777.3 bitrate= 224.0kbits/s
size= 21701kB time=793.7 bitrate= 224.0kbits/s
size= 22267kB time=814.3 bitrate= 224.0kbits/s
size= 22609kB time=826.9 bitrate= 224.0kbits/s
size= 23159kB time=847.0 bitrate= 224.0kbits/s
size= 23602kB time=863.2 bitrate= 224.0kbits/s
size= 24140kB time=882.8 bitrate= 224.0kbits/s
size= 24516kB time=896.6 bitrate= 224.0kbits/s
size= 25050kB time=916.1 bitrate= 224.0kbits/s
size= 25399kB time=928.9 bitrate= 224.0kbits/s
size= 25804kB time=943.7 bitrate= 224.0kbits/s
size= 26242kB time=959.7 bitrate= 224.0kbits/s
size= 26729kB time=977.5 bitrate= 224.0kbits/s
size= 27167kB time=993.5 bitrate= 224.0kbits/s
size= 27584kB time=1008.8 bitrate= 224.0kbits/s
size= 28135kB time=1028.9 bitrate= 224.0kbits/s
size= 28586kB time=1045.4 bitrate= 224.0kbits/s
size= 29096kB time=1064.1 bitrate= 224.0kbits/s
size= 29432kB time=1076.4 bitrate= 224.0kbits/s
size= 29961kB time=1095.7 bitrate= 224.0kbits/s
size= 30296kB time=1108.0 bitrate= 224.0kbits/s
size= 30829kB time=1127.5 bitrate= 224.0kbits/s
size= 31273kB time=1143.7 bitrate= 224.0kbits/s
size= 31779kB time=1162.2 bitrate= 224.0kbits/s
size= 32144kB time=1175.5 bitrate= 224.0kbits/s
size= 32676kB time=1195.0 bitrate= 224.0kbits/s
size= 33124kB time=1211.4 bitrate= 224.0kbits/s
size= 33492kB time=1224.9 bitrate= 224.0kbits/s
size= 33927kB time=1240.8 bitrate= 224.0kbits/s
size= 34400kB time=1258.1 bitrate= 224.0kbits/s
size= 34835kB time=1274.0 bitrate= 224.0kbits/s
size= 35280kB time=1290.2 bitrate= 224.0kbits/s
size= 35723kB time=1306.4 bitrate= 224.0kbits/s
size= 36283kB time=1326.9 bitrate= 224.0kbits/s
size= 36638kB time=1339.9 bitrate= 224.0kbits/s
size= 37142kB time=1358.3 bitrate= 224.0kbits/s
size= 37534kB time=1372.7 bitrate= 224.0kbits/s
size= 38091kB time=1393.0 bitrate= 224.0kbits/s
size= 38439kB time=1405.8 bitrate= 224.0kbits/s
size= 38939kB time=1424.0 bitrate= 224.0kbits/s
size= 39400kB time=1440.9 bitrate= 224.0kbits/s
size= 39739kB time=1453.3 bitrate= 224.0kbits/s
size= 40149kB time=1468.3 bitrate= 224.0kbits/s
size= 40696kB time=1488.3 bitrate= 224.0kbits/s
size= 41141kB time=1504.6 bitrate= 224.0kbits/s
size= 41596kB time=1521.2 bitrate= 224.0kbits/s
size= 42030kB time=1537.1 bitrate= 224.0kbits/s
size= 42574kB time=1557.0 bitrate= 224.0kbits/s
size= 42951kB time=1570.8 bitrate= 224.0kbits/s
size= 43439kB time=1588.6 bitrate= 224.0kbits/s
size= 43807kB time=1602.1 bitrate= 224.0kbits/s
size= 44361kB time=1622.3 bitrate= 224.0kbits/s
size= 44711kB time=1635.1 bitrate= 224.0kbits/s
size= 45252kB time=1654.9 bitrate= 224.0kbits/s
size= 45705kB time=1671.5 bitrate= 224.0kbits/s
size= 46243kB time=1691.2 bitrate= 224.0kbits/s
size= 46689kB time=1707.5 bitrate= 224.0kbits/s
size= 47236kB time=1727.5 bitrate= 224.0kbits/s
size= 47676kB time=1743.6 bitrate= 224.0kbits/s
size= 47978kB time=1754.6 bitrate= 224.0kbits/s
size= 48407kB time=1770.3 bitrate= 224.0kbits/s
size= 48965kB time=1790.7 bitrate= 224.0kbits/s
size= 49382kB time=1806.0 bitrate= 224.0kbits/s
size= 49934kB time=1826.2 bitrate= 224.0kbits/s
size= 50403kB time=1843.3 bitrate= 224.0kbits/s
size= 50949kB time=1863.3 bitrate= 224.0kbits/s
size= 51324kB time=1877.0 bitrate= 224.0kbits/s
size= 51843kB time=1896.0 bitrate= 224.0kbits/s
size= 52214kB time=1909.5 bitrate= 224.0kbits/s
size= 52681kB time=1926.6 bitrate= 224.0kbits/s
size= 53040kB time=1939.7 bitrate= 224.0kbits/s
size= 53559kB time=1958.7 bitrate= 224.0kbits/s
size= 54016kB time=1975.5 bitrate= 224.0kbits/s
size= 54458kB time=1991.6 bitrate= 224.0kbits/s
size= 54894kB time=2007.5 bitrate= 224.0kbits/s
size= 55424kB time=2026.9 bitrate= 224.0kbits/s
size= 55883kB time=2043.7 bitrate= 224.0kbits/s
size= 56219kB time=2056.0 bitrate= 224.0kbits/s
size= 56649kB time=2071.7 bitrate= 224.0kbits/s
size= 57139kB time=2089.6 bitrate= 224.0kbits/s
size= 57512kB time=2103.3 bitrate= 224.0kbits/s
size= 58029kB time=2122.2 bitrate= 224.0kbits/s
size= 58504kB time=2139.6 bitrate= 224.0kbits/s
size= 59055kB time=2159.7 bitrate= 224.0kbits/s
size= 59419kB time=2173.0 bitrate= 224.0kbits/s
size= 59928kB time=2191.6 bitrate= 224.0kbits/s
size= 60324kB time=2206.1 bitrate= 224.0kbits/s
size= 60783kB time=2222.9 bitrate= 224.0kbits/s
size= 61231kB time=2239.3 bitrate= 224.0kbits/s
size= 61701kB time=2256.5 bitrate= 224.0kbits/s
size= 62185kB time=2274.2 bitrate= 224.0kbits/s
size= 62615kB time=2289.9 bitrate= 224.0kbits/s
size= 63060kB time=2306.2 bitrate= 224.0kbits/s
size= 63588kB time=2325.5 bitrate= 224.0kbits/s
size= 63994kB time=2340.3 bitrate= 224.0kbits/s
size= 64428kB time=2356.2 bitrate= 224.0kbits/s
size= 64911kB time=2373.9 bitrate= 224.0kbits/s
size= 65410kB time=2392.1 bitrate= 224.0kbits/s
size= 65802kB time=2406.5 bitrate= 224.0kbits/s
size= 66249kB time=2422.8 bitrate= 224.0kbits/s
size= 66733kB time=2440.5 bitrate= 224.0kbits/s
size= 67046kB time=2452.0 bitrate= 224.0kbits/s
size= 67541kB time=2470.1 bitrate= 224.0kbits/s
size= 67997kB time=2486.8 bitrate= 224.0kbits/s
size= 68509kB time=2505.5 bitrate= 224.0kbits/s
size= 68892kB time=2519.5 bitrate= 224.0kbits/s
size= 69404kB time=2538.2 bitrate= 224.0kbits/s
size= 69883kB time=2555.7 bitrate= 224.0kbits/s
size= 70340kB time=2572.4 bitrate= 224.0kbits/s
size= 70742kB time=2587.1 bitrate= 224.0kbits/s
size= 71106kB time=2600.4 bitrate= 224.0kbits/s
size= 71569kB time=2617.4 bitrate= 224.0kbits/s
size= 72011kB time=2633.5 bitrate= 224.0kbits/s
size= 72454kB time=2649.7 bitrate= 224.0kbits/s
size= 72940kB time=2667.5 bitrate= 224.0kbits/s
size= 73397kB time=2684.2 bitrate= 224.0kbits/s
size= 73934kB time=2703.9 bitrate= 224.0kbits/s
size= 74369kB time=2719.8 bitrate= 224.0kbits/s
size= 74895kB time=2739.0 bitrate= 224.0kbits/s
size= 75156kB time=2748.6 bitrate= 224.0kbits/s
size= 75667kB time=2767.3 bitrate= 224.0kbits/s
size= 76109kB time=2783.4 bitrate= 224.0kbits/s
size= 76609kB time=2801.7 bitrate= 224.0kbits/s
size= 77049kB time=2817.8 bitrate= 224.0kbits/s
size= 77599kB time=2837.9 bitrate= 224.0kbits/s
size= 78041kB time=2854.1 bitrate= 224.0kbits/s
size= 78481kB time=2870.2 bitrate= 224.0kbits/s
size= 78910kB time=2885.9 bitrate= 224.0kbits/s
size= 79295kB time=2899.9 bitrate= 224.0kbits/s
size= 79717kB time=2915.4 bitrate= 224.0kbits/s
size= 80264kB time=2935.4 bitrate= 224.0kbits/s
size= 80709kB time=2951.7 bitrate= 224.0kbits/s
size= 81267kB time=2972.1 bitrate= 224.0kbits/s
size= 81609kB time=2984.5 bitrate= 224.0kbits/s
size= 82159kB time=3004.7 bitrate= 224.0kbits/s
size= 82604kB time=3021.0 bitrate= 224.0kbits/s
size= 83130kB time=3040.2 bitrate= 224.0kbits/s
size= 83505kB time=3053.9 bitrate= 224.0kbits/s
size= 83984kB time=3071.4 bitrate= 224.0kbits/s
size= 84400kB time=3086.6 bitrate= 224.0kbits/s
size= 84854kB time=3103.2 bitrate= 224.0kbits/s
size= 85294kB time=3119.3 bitrate= 224.0kbits/s
size= 85844kB time=3139.4 bitrate= 224.0kbits/s
size= 86272kB time=3155.1 bitrate= 224.0kbits/s
size= 86772kB time=3173.4 bitrate= 224.0kbits/s
size= 87221kB time=3189.8 bitrate= 224.0kbits/s
size= 87622kB time=3204.5 bitrate= 224.0kbits/s
size= 88001kB time=3218.3 bitrate= 224.0kbits/s
size= 88456kB time=3235.0 bitrate= 224.0kbits/s
size= 88937kB time=3252.6 bitrate= 224.0kbits/s
size= 89450kB time=3271.3 bitrate= 224.0kbits/s
size= 89840kB time=3285.6 bitrate= 224.0kbits/s
size= 90339kB time=3303.8 bitrate= 224.0kbits/s
size= 90822kB time=3321.5 bitrate= 224.0kbits/s
size= 91242kB time=3336.9 bitrate= 224.0kbits/s
size= 91573kB time=3349.0 bitrate= 224.0kbits/s
size= 92066kB time=3367.0 bitrate= 224.0kbits/s
size= 92509kB time=3383.2 bitrate= 224.0kbits/s
size= 92874kB time=3396.5 bitrate= 224.0kbits/s
size= 93327kB time=3413.1 bitrate= 224.0kbits/s
size= 93697kB time=3426.6 bitrate= 224.0kbits/s
size= 94075kB time=3440.5 bitrate= 224.0kbits/s
size= 94560kB time=3458.2 bitrate= 224.0kbits/s
size= 95158kB time=3480.1 bitrate= 224.0kbits/s
size= 95789kB time=3503.1 bitrate= 224.0kbits/s
size= 96292kB time=3521.5 bitrate= 224.0kbits/s
size= 96904kB time=3543.9 bitrate= 224.0kbits/s
size= 97510kB time=3566.1 bitrate= 224.0kbits/s
size= 98007kB time=3584.3 bitrate= 224.0kbits/s
size= 98620kB time=3606.7 bitrate= 224.0kbits/s
size= 99234kB time=3629.1 bitrate= 224.0kbits/s
size= 99882kB time=3652.8 bitrate= 224.0kbits/s
size= 100366kB time=3670.5 bitrate= 224.0kbits/s
size= 100983kB time=3693.1 bitrate= 224.0kbits/s
size= 101576kB time=3714.8 bitrate= 224.0kbits/s
size= 102106kB time=3734.2 bitrate= 224.0kbits/s
size= 102677kB time=3755.0 bitrate= 224.0kbits/s
size= 103329kB time=3778.9 bitrate= 224.0kbits/s
size= 103869kB time=3798.6 bitrate= 224.0kbits/s
size= 104402kB time=3818.1 bitrate= 224.0kbits/s
size= 104971kB time=3838.9 bitrate= 224.0kbits/s
size= 105612kB time=3862.4 bitrate= 224.0kbits/s
size= 106181kB time=3883.2 bitrate= 224.0kbits/s
size= 106749kB time=3903.9 bitrate= 224.0kbits/s
size= 107324kB time=3925.0 bitrate= 224.0kbits/s
size= 107960kB time=3948.3 bitrate= 224.0kbits/s
size= 108441kB time=3965.8 bitrate= 224.0kbits/s
size= 109056kB time=3988.3 bitrate= 224.0kbits/s
size= 109594kB time=4008.0 bitrate= 224.0kbits/s
size= 110235kB time=4031.5 bitrate= 224.0kbits/s
size= 110716kB time=4049.0 bitrate= 224.0kbits/s
size= 111336kB time=4071.7 bitrate= 224.0kbits/s
size= 111926kB time=4093.3 bitrate= 224.0kbits/s
size= 112456kB time=4112.7 bitrate= 224.0kbits/s
size= 113034kB time=4133.8 bitrate= 224.0kbits/s
size= 113679kB time=4157.4 bitrate= 224.0kbits/s
size= 114271kB time=4179.0 bitrate= 224.0kbits/s
size= 114799kB time=4198.4 bitrate= 224.0kbits/s
size= 115310kB time=4217.1 bitrate= 224.0kbits/s
size= 115951kB time=4240.5 bitrate= 224.0kbits/s
size= 116442kB time=4258.5 bitrate= 224.0kbits/s
size= 117071kB time=4281.5 bitrate= 224.0kbits/s
size= 117669kB time=4303.3 bitrate= 224.0kbits/s
size= 118304kB time=4326.5 bitrate= 224.0kbits/s
size= 118781kB time=4344.0 bitrate= 224.0kbits/s
size= 119399kB time=4366.6 bitrate= 224.0kbits/s
size= 119996kB time=4388.4 bitrate= 224.0kbits/s
size= 120553kB time=4408.8 bitrate= 224.0kbits/s
size= 121036kB time=4426.4 bitrate= 224.0kbits/s
size= 121694kB time=4450.5 bitrate= 224.0kbits/s
size= 122252kB time=4470.9 bitrate= 224.0kbits/s
size= 122812kB time=4491.4 bitrate= 224.0kbits/s
size= 123371kB time=4511.9 bitrate= 224.0kbits/s
size= 124034kB time=4536.1 bitrate= 224.0kbits/s
size= 124595kB time=4556.6 bitrate= 224.0kbits/s
size= 125239kB time=4580.2 bitrate= 224.0kbits/s
size= 125765kB time=4599.4 bitrate= 224.0kbits/s
size= 126444kB time=4624.2 bitrate= 224.0kbits/s
size= 126835kB time=4638.5 bitrate= 224.0kbits/s
size= 127337kB time=4656.9 bitrate= 224.0kbits/s
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [mplex] File /Users/adam/Documents/warez/Blair Witch Project I and II/blairwitch1.avi.ff.m2v looks like an MPEG Video stream.
INFO: [mplex] File /Users/adam/Documents/warez/Blair Witch Project I and II/blairwitch1.avi.ff.mp2 looks like an MPEG Audio stream.
INFO: [mplex] Video stream 0: profile 4 selected - ignoring non-standard options!
INFO: [mplex] Found 1 audio streams and 1 video streams
INFO: [mplex] Selecting SVCD output profile
INFO: [mplex] Multiplexing video program stream!
INFO: [mplex] Scanning for header info: Video stream e0 (/Users/adam/Documents/warez/Blair Witch Project I and II/blairwitch1.avi.ff.m2v)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 480
INFO: [mplex] Frame height : 576
INFO: [mplex] Aspect ratio : 4:3 display
INFO: [mplex] Picture rate : 25.000 frames/sec
INFO: [mplex] Bit rate : 2500000 bits/sec
INFO: [mplex] Vbv buffer size : 229376 bytes
INFO: [mplex] CSPF : 0
INFO: [mplex] Scanning for header info: Audio stream c0 (/Users/adam/Documents/warez/Blair Witch Project I and II/blairwitch1.avi.ff.mp2)
INFO: [mplex] MPEG AUDIO STREAM: c0
INFO: [mplex] Audio version : 1.0
INFO: [mplex] Layer : 2
INFO: [mplex] CRC checksums : no
INFO: [mplex] Bit rate : 28672 bytes/sec (224 kbit/sec)
INFO: [mplex] Frequency : 44100 Hz
INFO: [mplex] Mode : 0 stereo
INFO: [mplex] Mode extension : 0
INFO: [mplex] Copyright bit : 0 no copyright
INFO: [mplex] Original/Copy : 1 original
INFO: [mplex] Emphasis : 0 none
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 2771544
INFO: [mplex] target data-rate specified : 2788800
INFO: [mplex] Setting specified specified data rate: 2788800
INFO: [mplex] Run-in Sectors = 78 Video delay = 46800 Audio delay = 50400
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 235520 frame=000000 sector=00000000
INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000
++ WARN: [mplex] File size exceeded before split-point in video stream
INFO: [mplex] Starting new output file...
INFO: [mplex] Scanned to end AU 116422
INFO: [mplex] STREAM e0 completed @ frame 116422.
++ WARN: [mplex] Discarding incomplete final frame MPEG audio stream c0!
INFO: [mplex] STREAM c0 completed @ frame 178270.
INFO: [mplex] Multiplex completion at SCR=419163600.
INFO: [mplex] Video e0: buf= 222592 frame=116422 sector=00567834
INFO: [mplex] Audio c0: buf= 2634 frame=178270 sector=00056792
INFO: [mplex] VIDEO_STATISTICS: e0
INFO: [mplex] Video Stream length: 1296718424 bytes
INFO: [mplex] Sequence headers: 7904
INFO: [mplex] Sequence ends : 1
INFO: [mplex] No. Pictures : 116422
INFO: [mplex] No. Groups : 7904
INFO: [mplex] No. I Frames : 7904 avg. size 20249 bytes
INFO: [mplex] No. P Frames : 31081 avg. size 13080 bytes
INFO: [mplex] No. B Frames : 77438 avg. size 9428 bytes
INFO: [mplex] Average bit-rate : 2227200 bits/sec
INFO: [mplex] Peak bit-rate : 3153200 bits/sec
INFO: [mplex] BUFFERING min 15 Buf max 133508
INFO: [mplex] AUDIO_STATISTICS: c0
INFO: [mplex] Audio stream length 130392509 bytes.
INFO: [mplex] Syncwords : 178272
INFO: [mplex] Frames : 101867 padded
INFO: [mplex] Frames : 76405 unpadded
INFO: [mplex] BUFFERING min 15 Buf max 746
INFO: [mplex] MUX STATUS: no under-runs detected.
(Super) VideoCD xml description created successfully as `blairwitch1.avi.xml'
++ WARN: initializing libvcd 0.7.12 [darwin5.2/powerpc]
**ERROR: could not stat() file `blairwitch1.avi': No such file or directory
++ WARN:
++ WARN:
(Super) VideoCD xml description created successfully as `blairwitch1.avi.ff-1.mpg.xml'
**ERROR: could not stat() file `blairwitch1.avi.ff-1.mpg': No such file or directory
++ WARN:
++ WARN:
(Super) VideoCD xml description created successfully as `blairwitch1.avi.ff-2.mpg.xml'
**ERROR: could not stat() file `blairwitch1.avi.ff-2.mpg': No such file or directory
++ WARN:
++ WARN:
(Super) VideoCD xml description created successfully as `blairwitch2.avi.xml'
**ERROR: could not stat() file `blairwitch2.avi': No such file or directory
++ WARN:
++ WARN:
Encoding completed on Tue Oct 25 18:41:49 CDT 2005
ffmpegX and/or Toast 8 - Loss of video quality in converting to DVD
By bonespur in forum MacReplies: 2Last Post: 9th Mar 2011, 01:52 -
Newbie Question about Avi's, ffmpegx and Toast
By pmmassacre in forum ffmpegX general discussionReplies: 12Last Post: 25th Apr 2009, 23:38 -
ffmpegX and Popcorn 2/Toast 6 (Light)
By charliel52 in forum ffmpegX general discussionReplies: 1Last Post: 30th Aug 2008, 14:10 -
AVI won't burn in Toast 7 (need to convert or repair?)
By 3lutz3toe in forum ffmpegX general discussionReplies: 4Last Post: 1st Aug 2007, 16:07 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
