I am trying to download the reallib package for ffmpegX so that I can encode realmedia videos. I download the file and then open it and put it in my library/applications support/ffmpegX folder but it still won't encode. Some Please help...
yah it comes up like this
Encoding started on Tue Oct 25 18:13:19 EDT 2005
MEncoder dev-CVS-050814-13:46-3.3 (C) 2000-2005 MPlayer Team
Mac OSX static build for ffmpegX
AltiVec found
CPU: PowerPC
success: format: 0 data: 0x0 - 0x26246cf
REAL file format detected.
Stream description: Audio Stream
Stream mimetype: audio/x-pn-realaudio
Stream description: Video Stream
Stream mimetype: video/x-pn-realvideo
Stream mimetype: logical-fileinfo
VIDEO: [04VR] 400x300 24bpp 30.000 fps 0.0 kbps ( 0.0 kbyte/s)
[V] filefmt:11 fourcc:0x30345652 size:400x300 fps:30.00 ftime:=0.0333
Error: dlopen(/Library/Application Support/ffmpegX/reallib/cook.so, 1): image not found
Did you use the stable build from http://prdownloads.sourceforge.net/mplayerosx/reallib.zip?download ?
I tried that and got the same thing. But when I first intalled ffmpegX there was no folder for it in application support so I made on. Maybe this is the problem?
In the Utilities folder that is in the Applications folder there is a utility called "Disk Utility"
Launch it, select your hard drive in the list on the left, and then click the repair permissions button on the bottom.
Like I said this might help if some folders and files have the wrong permissions, but odds are this is not the issue. I just mentioned it since you said you had to manually create folders and there is an outside chance this might help.
Alph
Reallib package installation doesn't work for me
By caixiaoeva in forum ffmpegX general discussionReplies: 18Last Post: 30th Oct 2010, 15:20 -
Complete Authoring Package please?
By 1RealNewbie in forum Authoring (DVD)Replies: 3Last Post: 28th Sep 2009, 07:09 -
Best video editing package?
By donski in forum EditingReplies: 4Last Post: 3rd Jul 2009, 06:55 -
can't play rm in mplayer on mac osx--did install reallib codecs
By onesuch in forum MacReplies: 2Last Post: 20th Dec 2007, 00:56 -
Latest OS X reallib binaries?
By Scallywag in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jun 2007, 17:26
