Is there a program which will check a system and make sure that the codec's for VCD playback have been loaded correcly?
And if not find suggest where to get them and install them?
I have tried all the hints here to get MS-MediaPlayer Ver7.1 to play VCD created with 'NERO' and keep getting a not supported format error!?!
yea jusy got to Start->Setting->Control Panel->Multimedia->Devices Audio or Video COmpression Codec
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
But what codecs and versions should I be looking for and if they are not there where does one start looking for the device drivers and getting them installed?
PowerDVD plays... but I have tried to watch a VCD on two other non-DVD-ROM computers that do not have PowerDVD and the VCD fails on both of them! All three systems have MS-Media Player V7.1 running Win98SE
--David -
Install the MPEG2 Codec that can be found on the Tools section of this site. Surely it will play VCD's after that.
There R 3 sides on every story;
Yours, Mine and the truth -
On 2001-12-27 09:59:45, Mars-L wrote:
Install the MPEG2 Codec that can be found on the Tools section of this site.</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Been there and done that....
It seems that it is the format used by NERO to create the photo VCD as MediaPlayer will play a true MPEG file such as the demo that can be downloaded from this web site.
--David -
Go to the tools section and install the Nimo Codec pack.
Chances are that whatever codec you are missing is in there...
On 2001-12-27 22:59:32, aguillon wrote:
Go to the tools section and install the Nimo Codec pack.</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Before I go adding more codec's to my system.. if you use NERO create a quick PHOTO VCD and tell me if you can view the created disc with MS-MediaPlayer first... I have a feeling that alot of the suggestions are coming from well meaning folks that have not tried the cure themself.
You see I have a 'Test' system that is a 'FRESH' install of Win98SE and has been fully updated from the Windows update web site and the 'Test' system will not play back these NERO created PHOTO VCD's.. but will playback 'MOVIE' VCD's
--David
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 15:10 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 20:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 10:41 -
"Check to make sure you have the required codec"
By andy_blah in forum SubtitleReplies: 2Last Post: 8th Aug 2008, 12:58 -
Check this out!
By mikee55 in forum Off topicReplies: 6Last Post: 18th May 2007, 12:17
