  1. Heya guys I am trying to find a template or a program to print for the Half Size DVD Cases they are like a DVD Version of the standard CD Cases if you get what I mean.
    Get out a ruler and take measurements.
  3. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    I think what LS is trying to say is you can adjust the printed image size either through your printing software or a image editing application.
  4. ok after much messing about and lots of paper down the drain I have got it to 13.5cm tall (think that means length) 25cm width anyone able to create a template for any DVD Labeling Program like Acoustica or another one as I am unsure how to make one for these programs.
    Ok I have SureThing Deluxe on and cannot seem to get the template right and the help file is not very helpful can anyone assist ?
    Jun 2005
    m/bro uk
    hi there m8 ive just found a programe that might help do u mean slim dvd half size box if u do
    undercover xp v1.09 if this helps let me no
    thanks for your help
  6. Banned
    Oct 2005
    (post removed ... another alias to a banned member)
    When I started doing DVD work, most people didn't know DVD burners had been invented. There were no sites like this (videohelp.com was vcdhelp.com at the time, strictly VCD and SVCD info), no templates, nothing.
    I pulled out my DVD case, pulled out a ruler, measured the length, the height, and the width and position of the spine. It took me all of 2 minutes.
    I opened Photoshop, sized a 300dpi canvas with those dimensions, and then drug out guides for the spine.
    Then add in the fact that no two cases are alike (the measurements can range a mm or so in size, due to varied gluing methods). So to this day, when I get in new cases, I pull out my ruler and measure, to verify my own self-made templates. Usually have to adjust them a bit.
