Haven't run into this situation with previous versions of SVCD2DVD (currently using 2.0.2117.24512), of course I may not have had assets of mixed aspect ratios, either...
My current project has two assets: one 4:3 source (512x384) and one 16:9 source (624x352). Both files are XVID and both are NTSC (film) at 23.976 FPS.
It seems that no matter what settings I use, the resulting DVD turns out full screen (4:3) ... no problem for the 4:3 source, but the 16:9 source also is rendered in 4:3 (vertically stretched).
What SVCD2DVD settings should be used so the 4:3 title set comes out 4:3 and that the 16:9 title set comes out 16:9?
I am creating a (silent) menu, not a QUICK DVD ...
Please do not hesitate to request any information I have failed to provide.
Thanks for your help!
Are they in seperate VTSs? What is the duration of each asset? During the encoding what bitrate is being used?
CB,
Yes, seperate VTSs.
16:9 asset
AV Details ===================
FormatName=avi
Num_Frames=57951
DurationInSecs=2416
Duration=00:40:16.7
VideoCodec=mpeg4
Width=512
Height=384
Standard=NTSC (Film)
BitRate=1220
AudioStreamCount=1
Audio1SampleRate=48000
Audio1Codec=mp3
Audio1BitRate=128
Audio2SampleRate=-1
Audio2Codec=NULL
Audio2BitRate=-1
4:3 asset:
FormatName=avi
Num_Frames=58914
DurationInSecs=2456
Duration=00:40:56.9
VideoCodec=mpeg4
Width=624
Height=352
BitRate=1200
AudioStreamCount=1
Audio1Codec=mp3
Audio1BitRate=128
Audio2SampleRate=-1
Audio2Codec=NULL
Audio2BitRate=-1
Thanks for your prompt response! -
ok. can you send me a sample of the 624*352 avi? (use the makesample tool in the tools folder) Say 5MB? Can you email that along with your existing log file too and I'll take a deeper look.
ChrissyBoy,
Samples & logs sent via e-mail.
Aspect Ratio Question
By rede96 in forum Newbie / General discussionsReplies: 5Last Post: 14th Aug 2011, 05:17 -
Aspect Ratio Question + Some
By Alexander4444 in forum Video ConversionReplies: 7Last Post: 9th May 2011, 03:17 -
By kelticvixen in forum Newbie / General discussionsReplies: 3Last Post: 12th Jan 2009, 14:27 -
aspect ratio question
By brianhj in forum Video ConversionReplies: 6Last Post: 16th Aug 2008, 13:54 -
Aspect Ratio Question (Sorry!)
By rede in forum Newbie / General discussionsReplies: 12Last Post: 30th Dec 2007, 08:25
