Hello.
I downloaded a video off of a tech site and I noticed that the Audio is not in sync with the video by like 3-8 secs. Is there an editing program that I can use that will preview the output of sorts instead of me guessing and encoding with TMPGENC?
If you're wondering, its a MPEG2 (at DVD Specification) Video File.
thanks!
BUMP
Anybody have any suggestions? -
I just downloaded syncview and it crashes everytime I open the installer.
So..any other suggestions? -
Hypercube Time Stretcher doesn't work very well. Seems to make it worse than it was in the 1st place.
Anymore ideas? -
Use VirtualDubMpeg2 and check the File Information. It will report the Audio Skew in +/- mili-seconds.
Enter that number in Audio/Interleaving/Audio Skew Correction. Then frame serve to TMPGEnc or save as an AVI.
Hope this helps,
Chas
Program to visually sync audio and video?
By rayden54 in forum AudioReplies: 4Last Post: 14th Dec 2011, 06:38 -
Looking for a good editing program
By JCWBobC in forum EditingReplies: 4Last Post: 8th Sep 2009, 10:15 -
Good Program / codec to encode Flash Vp6 files to avi? Audio is Out of Sync
By hypnoticpimp in forum Video Streaming DownloadingReplies: 1Last Post: 14th Jul 2008, 00:25 -
Audio/Video Out of Sync/Lag When Editing Clips
By DrawnIntoIt88 in forum EditingReplies: 2Last Post: 15th Dec 2007, 08:03 -
Good free program to join .mpa audio and .mpg video ?
By geek2330 in forum Newbie / General discussionsReplies: 6Last Post: 5th Nov 2007, 09:34
