I have filled my 250G hard drive with vobs already. I used DVDShrink without compression creating one large vob. This works great to view over the network with a Buffalo LinkTheater, but I need to compress. Is there anything out there that will take a 4-6 Gig VOB and convert/compress without too much of a loss in quality? Thanks in advance
Gordian knot, maybe?
“He who makes a beast of himself gets rid of the pain of being a man.” -
I'd go AutoGK and convert to XVID, or Windows Movie Maker and convert to WMV with the High Quality video (large) template.
Quality (or loss of) is all about the settings you use.If in doubt, Google it. -
ReJig is by far the best program for squishing down mpeg-2 files without introducing visible compression artifacts. You can probably squeeze your 4 gig mpeg-2 file down to around 3 gigs using ReJig without any visible compression artifacts at all, and if you want to get more extreme you coudl probably squish it down to 2 gigs or less without offensive compression artifacts.
Best of all, ReJig is freeware.
How do I merge and compress VOB files?
By Mickie in forum Video ConversionReplies: 12Last Post: 23rd Jul 2011, 23:30 -
Need To Compress Large AVI For Youtube
By r04dw4rri0r in forum Newbie / General discussionsReplies: 6Last Post: 30th Dec 2010, 10:18 -
Help to compress large HD File
By camlachie in forum Video ConversionReplies: 10Last Post: 10th May 2009, 12:47 -
Compress .VOB
By Weezer71 in forum Video ConversionReplies: 11Last Post: 31st Jan 2009, 11:57 -
compress the .VOB file
By akakiami in forum DVD RippingReplies: 10Last Post: 19th Aug 2008, 07:30
