I am using DVDlab1.5XX
I have put together some trailers(6 total) that are 4:3 ratio and two that are 16:9 into two separate movies....ie VTS 1 and VTS 2. These two movies have chapters indicating the beginning of each trailer.
I want to have a play all button that will play the first 3 chapters of movie 1 (VTS1) then two chapters of Movie 2 (VTS 2)....then back to play remaining
chapters from movie 1(VTS1).
Is there a way of doing this using branching objects..or something similar.
I am trying some more complicated DVD menu for first time.
Remember that movie one(6 chapters or trailers) is 4:3 and movie two is 16:9 (two chapters or trailers)
TIA
Aussiemac
Results 1 to 13 of 13
you could setup Chapter Playlists, and link them with together in a master playlist...
George -
Create a branch for each chapter in it's respective VTS. One chapter per branch.
Create a regular playlist by selecting connection tab> add> playlist.
Open playlist and play branches in any order you like. (Draw connections from each branch back to the playlist just to be on the safe side.) -
I am trying to do something similar, but without menus. I have a 4:3 clip that I want to mix with 16:9s and TMP is giving me a problem. I tried using DVDPatcher, but no use. Any other hints? I didn't understand the VTS branching stuff up above...
Ahh...may bad! I was looking for highlighted blue text for tools, but I didn't see any. Sorry! I am using TMPEngc DVD Author and have tried Nero Express and DVDPatcher to trick it, byt it didn't work.
I want to do playall in DvdLab Pro. However, I don't know how to do new VTS:es. As of this moment, I've got 43 "movies" in VTS1 >_>'
EDIT: Found it. What's the diff between a VTS and a VMG menu? -
Originally Posted by FallenAngelII
Originally Posted by non-linear
Bookmarked.
I only did one playlist.
Connections -> Add -> Playlist
And then I added the 4 movies that were to play. Is this correct? Will they play in the order I specified? How do I set which menu the playlist will return to or will it return to the menu that the last clip specifies?
MKV DvdRip Xvid Downloads Play on WMP but wont play on my PVR
By dashas in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2011, 05:15 -
Any Programs Have Better System than Long Play, Extended Play?
By johnharlin in forum Video ConversionReplies: 3Last Post: 10th Jul 2009, 19:04 -
How do I play/convert .MP4 files to play on my laptop
By tfoster in forum Newbie / General discussionsReplies: 1Last Post: 25th Jul 2008, 20:23 -
how to play mp3's randomly in folder without play lists
By deejay.2001 in forum Software PlayingReplies: 4Last Post: 22nd Apr 2008, 13:27 -
Avid Lquid 7 menus..play chapter and play all
By cheesypuffs in forum Newbie / General discussionsReplies: 3Last Post: 24th Aug 2007, 01:34
