Does final cut express cpautre 4 channel audio as i have to a use radio mic and the onboard mic, how does it appear on the timline .
john
camera..xl1s
I've not heard of a method for capturing audio from TWO ports (into one program) simultaneously on the Mac. It certainly would be possible to send the audio through a four-channel external box and then into the digital audio port (assuming your Mac is a G5) (or USB or FireWire, depending on the interface on the external box).
It also might be possible to set up two separate audio capture apps and configure each to look at a different port. Assuming this can be done, FCE could then import the two separate stereo streams. You'd then align them on two separate stereo tracks. -
Perhpas you'd like to re-phrase your question, then, as no one else has responded; your meaning is unclear.
Capturing from HV30 into fce
By birdclaw in forum Capturing and VCRReplies: 1Last Post: 8th Dec 2010, 16:23 -
VirtualDub Mod Conversion from DVD, no audio in FCE
By Jralph in forum Video ConversionReplies: 2Last Post: 29th Apr 2009, 11:09 -
Newb FCE Question
By Jralph in forum MacReplies: 3Last Post: 17th Apr 2009, 11:56 -
inconsistent audio sample rate error in FCE...
By ednarophati in forum MacReplies: 1Last Post: 23rd Aug 2007, 14:59 -
chroma keying on FCE
By ednarophati in forum MacReplies: 3Last Post: 3rd Jul 2007, 21:02
