Results 1 to 10 of 10
  1. Hi
    I have just installed XP on a new hard drive and when trying to install SVCD2DVD get the following message:
    "The advertised aplication will not be installed because it might be unsafe. Contact your administrator to change the installation user interface option of the package to basic"
    Anyone help?
    Cheers
    Banny
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Make sure you have the latest build. Save the .msi file to the root of your system drive (i.e c:\ for example)and attempt to reinstall.
  3. ChrissyBoy
    Tried it but no luck.
    It worked fine before I reinstalled XP.
    Any more ideas?
    Banny
  4. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Do you have administrators rights on the PC?
  5. & .net Framework installed?
  6. Yes and yes
    Anything else?
    ta
  7. OK managed to get it installed by using command prompt and typing svcd2dvdsetup.msi /qb
    BUT, now getting message:
    Please wait a few seconds whilst your machine license is generated...
    Unable to connect to the Registration server.
    Please click the 'Back' button followed by the 'Next' button to try again.
    Help!
  8. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Good news on the install. Reg Server is back up so you should be ok now.
  9. More probs.
    Uninstalled it and clened the registry of all SVCD2DVD and BadgerIt entries.
    Re-installed and when I try to run it I get "preparing to install" then "Fatal error during installation"
  10. Now found out it is a problem with the shortcut in the shortcut.
    It now has registered fine and looks ok - I'll process some files and keep my fingers crossed
    thanks for the help
    Banny
