Hi I'm having such similar issue with germ, plus some new error msg. may i know how did you help germ to resolve?
Error msg 1
/Users/fredlee/Desktop/34.rmvb: I/O error occured
Usually that means that input file is truncated and/or corrupted.
[when using mplayer or real player, it plays perfectly fine with video and audio as well. I tried changing the file name to .rm and still the same]
Error msg 2
Encoding started on Sun Oct 23 17:22:16 GMT-8 2005
[NULL @ 0x4199e0]Unsupported video codec
Input #0, rm, from '/Users/fredlee/Desktop/01.rmvb':
Duration: 00:43:54.0, start: 0.000000, bitrate: 524 kb/s
Stream #0.0: Audio: 0x0000, 32 kb/s
Stream #0.1: Video: RV40, 512x384, 12.00 fps, 486 kb/s
Stream #0.2: Data: 0x0000
Codec type mismatch for mapping #0.0 -> #0.0
[this is the same as germ. again it reads perfectly fine in mplayer or real player]
Appreciate your help.
Thanks.
Results 1 to 1 of 1
ffmpegX not encoding properly -- fails after 7%
By larrryc in forum ffmpegX general discussionReplies: 2Last Post: 22nd Apr 2010, 15:07 -
RMVB conversion end up without audio
By alc112 in forum Video ConversionReplies: 22Last Post: 14th Jan 2010, 01:34 -
pls. help: converting .rmvb files using ffmpegX
By Dolly in forum ffmpegX general discussionReplies: 4Last Post: 18th Jun 2009, 15:32 -
ffmpegX to convert rmvb
By Ninacita in forum ffmpegX general discussionReplies: 7Last Post: 31st Jan 2009, 23:14 -
flv > mov conversion fails, empty file, why?
By sduck409 in forum ffmpegX general discussionReplies: 2Last Post: 5th Feb 2008, 23:04
