I have some small DVD-Video segments in VOB that I want to put in a Powerpoint presentation. I'd like to convert the VOBs to WMV. How do I do this?
Results 1 to 12 of 12
Convert to MPEG first. Then Windows Movie Maker should accept them and do a conversion to WMV.
VOB to MPEG: https://www.videohelp.com/forum/viewtopic.php?t=224833 -
WMM and MPEG-2 don't mix.
Try this:
https://www.videohelp.com/forum/viewtopic.php?p=1353035#1353035If in doubt, Google it. -
jimmalenko, that shows how much I use WMM.
But here may be a useful tutorial for video and PowerPoint presentations:
http://www.presentations.com/presentations/creation/article_display.jsp?vnu_content_id=1258067 -
Originally Posted by jimmalenko
Originally Posted by junkmalle
https://www.videohelp.com/forum/viewtopic.php?p=1379600#1379600
Just out of interest, what MPEG-2 codecs have you got installed ?If in doubt, Google it. -
Thanks for the great advice. I have downloaded VirtualDub-MPEG2 and WOW - it does exactly what I want. I had not come across it in my (extensive) searches here, so thanks for pointing it out.
EXCEPT that: I am getting some bad A/V sync issues. I have found the Audo Skew Correction menu item, but I wonder: is there an easier way to either (a) avoid sync problems in the first place or (b) adjust the skew more easily than trial and error.
Thanks. -
These don't really address the cause of sync loss but can correct some.
SyncView and Hypercube Time Stretcher.
If you are cutting parts from MPEG videos, that can cause sync problems at times. If you are going to AVI, you might want to do that conversion before doing the editing.
Converting VOB to WMV
By pckipling in forum Video ConversionReplies: 4Last Post: 6th Feb 2010, 13:53 -
VOB or wmv to avi
By mauricemaurice in forum MacReplies: 10Last Post: 22nd Jun 2009, 13:03 -
Best Possible Quality .WMV From VOB
By jeff.mikolai in forum DVD RippingReplies: 3Last Post: 20th Feb 2008, 20:32 -
VOB to WMV!!!!
By guitarparth in forum Newbie / General discussionsReplies: 5Last Post: 27th Oct 2007, 05:34 -
wmv to vob
By angryassdrummer in forum Video ConversionReplies: 1Last Post: 7th May 2007, 04:01
