You know that all of this is over a damb weed!
So where am I going wrong?
Results 31 to 60 of 62
IS IT SUPPOSED TO SMOKE LIKE THAT?
Trying this between the tags: [img]minicd12.1034RB.bmp[/img]
you're putting just the filename.bmp in between the tags, right? Not the whole directory it sits on?
SM
Would you like to try the original picture before I bastardized it with paint?IS IT SUPPOSED TO SMOKE LIKE THAT? -
...and you changed the file's extension on your comp to bmp? Not just changing it in the post?
Originally Posted by Shadowmistress
I copied it straight from your reply and went the post window hit IMG hit paste hit IMG* and submit
the second try I browsed to the file and then did the aboveIS IT SUPPOSED TO SMOKE LIKE THAT? -
try as in smoke? ???
I did use the original pic as it got downloaded from email. I tried downloading it again and it would only let me save as bmp, not giving me any other choice. Here it is again:
Step 1: rename the file on your comp to zapper.bmp
Step 2: post reply, browse to zapper.bmp and have it ready to load.
Step 3: type [img]zapper.bmp[/img]
Submit -
Also don't have more the one "." in the file name. just mypic.jpg not mypic.12.jpg. That might confuse it.
LOL. Think you were doubling up on the img tags maybe? Or forgetting to load along with typing the name & tags? Try it with a bunch of other pics till you get the hang of it.
(Just make sure they're in proper format this time.)
Alright I can accecpt that when I resized in Paint that it ended up as a bmp maybe
But here is the deal, my original was like a 640X480 150KB straight from the cam to the PC
How do I choke it down to avoid all of this nonsence?IS IT SUPPOSED TO SMOKE LIKE THAT? -
Straight from the cam to the pc? Are you sure it's in a proper jpg format? Could be lying to you.... ?
Try this: just open it in any paint program and save it again as jpg. But don't just hit save, like, browse to the actual format and save as. See if that fixes it. -
I don't know? I am looking into that right now
lol. So it was the cam that was the culprit huh? Ah well, live and learn.
I think maybe. I have had problems before and I always thought that it was unsupported file types like cad drawings and such. I have also thought that the dozen or so different photo softwares that I had where botching things up. I am going to do a few more for luck.
Big thanks!IS IT SUPPOSED TO SMOKE LIKE THAT?
Is there a small test video one can use to test Rec 601 / 709 conversion?
By Asterra in forum Video ConversionReplies: 5Last Post: 19th Jun 2011, 09:28 -
[b][url]TEST! TEST TEST! WHAT"S THE BEST?!!!!!!!111111
By lordsmurf in forum TestReplies: 0Last Post: 2nd Aug 2010, 03:30 -
Need to make test tool to test Dolby
By djai in forum AudioReplies: 0Last Post: 9th Jun 2010, 07:01 -
Test,test amd propus 630
By budz in forum TestReplies: 20Last Post: 1st Jun 2010, 01:46 -
photo cd's
By backdrop001 in forum Newbie / General discussionsReplies: 2Last Post: 10th Jul 2007, 19:02
