stand back!
Results 1 to 30 of 62
First you have to upload your pic onto the forum. Browse and select it but only place the name between the image tags, not the directory. Also, make sure there are no spaces in the filename or weird characters cause that causes it to choke. (I'm not sure if all the extra periods might be the problem in this one.) Submit it.
[img]minicd12.1034ra.jpg[img]
Once it's uploaded it must remain there if you wish to hotlink to it from another board. If that's the case, you need to quote your post to find the proper link.
[img]https://www.videohelp.com/forum/images/guides/1394450/minicd12.1034ra.jpg[/img]
As far as I can tell, your pic is not on the forum database. -
try taking the periods out of the name.
you're file isn't over 150 kb, is it? -
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
Originally Posted by Conquest10
Oh yeah. Rub my face in it
IS IT SUPPOSED TO SMOKE LIKE THAT? -
The rest is fine.
filename.jpg -
Oh, looks like a problem again.
that ain't the oneOriginally Posted by ShadowmistressIS IT SUPPOSED TO SMOKE LIKE THAT?
Make sure that it has no spaces in the actual name not just what you put into the post.
It's because it's a bmp not a jpg
The file I got was named minicd12.1034RB.jpg. I renamed it to zappic and hit save but when I looked in my folder it was saved as bmp. So I loaded the bmp instead without touching it.
Is there a small test video one can use to test Rec 601 / 709 conversion?
By Asterra in forum Video ConversionReplies: 5Last Post: 19th Jun 2011, 08:28 -
[b][url]TEST! TEST TEST! WHAT"S THE BEST?!!!!!!!111111
By lordsmurf in forum TestReplies: 0Last Post: 2nd Aug 2010, 02:30 -
Need to make test tool to test Dolby
By djai in forum AudioReplies: 0Last Post: 9th Jun 2010, 06:01 -
Test,test amd propus 630
By budz in forum TestReplies: 20Last Post: 1st Jun 2010, 00:46 -
photo cd's
By backdrop001 in forum Newbie / General discussionsReplies: 2Last Post: 10th Jul 2007, 18:02
