Total newb here. Love the site!
I'm working with a 40-minute, 8.3GB avi file captured from DV camera. Converted to DVD mpeg (m2v right?) using DIKO took about 3 hours to get a 2.3GB m2v file. Diko all-in-one solution didn't work for me so I went to ffmpeggui to encode audio to ac3, and tpmgenc dvd author 1.6.
Following basic and advanced guides on afterdawn.com I think I was able to author a DVD. I added 17 chapters and created a motion menu. Then went to output and burned directly using the writing tool.
I guess I should've known something was up when the output took only 4 minutes. Anyway, the finished DVD runs on my player. I get a really cool motion menu but when I press "play" I get about one second of video and then back to the menu.
Any idea where I'm screwing up?
Thanks!
what is the size of the authored dvd?
are you using latest version of tmpgenc dvd author? or tmpgenc dvd author pro? -
using TPMGEnc DVD Author 1.6 (non-pro)
"Capacity of the created DVD: 2330/4438MB" -
so the burned dvd is 2330MB?
tried played it with a software dvd player? -
Tried it on PC - PowerDVD - same results: perfect motion menu and no play. Only a split second flash of the opening scene no matter which chapter is selected. Then back to the menu. Has anyone experienced this?
I really think the problem is within TPMGEnc DVD Author. I tried the same project with no menu and the output phase took less than a second. -
Been away from this project for a while but I thought I'd update B and anyone else interested.
The original capture was done through an integrated firewire on my audigy sound card. I read somewhere here that it could cause problems, so I shelled out for a dedicated firewire card and did a new capture. It seemed to do the trick.
Now I've got the full video....but no sound. Haven't been able to spend time on this issue yet but hoping it's a more documented problem.
Thanks B
Do you author/create Blu-ray or HD content? Let's get organized...
By lordsmurf in forum Authoring (Blu-ray)Replies: 11Last Post: 25th Aug 2009, 16:13 -
Exit to DVD-ROM content from a DVD menu
By SCDVD in forum Authoring (DVD)Replies: 7Last Post: 13th May 2009, 19:59 -
TPMGEnc DVD Author 3.0.9.166 crashes on writing to disc
By gayclarke in forum Authoring (DVD)Replies: 4Last Post: 10th Oct 2007, 03:40 -
How to author HD content???
By TheAdMan in forum Authoring (DVD)Replies: 1Last Post: 22nd Sep 2007, 21:56 -
TPMGEnc DVD Author 3 Menu Problem
By ^D3vIL^ in forum Newbie / General discussionsReplies: 4Last Post: 16th Sep 2007, 17:43
