Hi! I am trying to capture from VHS to DV using Canopus ADVC1394 PCI card. I have tried using WinProducer 3.0 (it came bundled) and also Adobe Premiere 6.5 but I notice that although I don't get any dropped frames but there is a very visible and consistent Green vertical bar at the right hand of the frame which is roughly 1/4 of an inch wide.
I understand that a distorted orizontal bar at the bottom of the frame occurs as a result of the capture card capturing full frame including the overscan area. But I don't understand why I am getting this vertical bar at the right hand side of the frame?
Secondly I noticed that my captured video does'nt look as good as my original analog footage. The colours look a little dull and dark and the look and feel of the video is not as the original video. I am using a JVC S-VHS deck with TBC + Datavideo TBC-3000.
Is it that DV quality actually looks like what I am getting or am I doing something wrong? Any help will be appreciated.
Always try to make an informed choice
I have a Canopus ADVC-50 and the picture quality from my JVC + TBC is very good. I use the WinDV to capture mostly (on occasion Dvapp) and what I see on screen will be what the captured video will look like.
Give WinDV a go and see how you get on with that.
Regards the green bar, I wonder if the TBC may be causing that as some tapes do end up worse if using a TBC, although I have not seen this particular problem. As a guess, try different set ups: Datavideo off/JVC's TBC off, Datavideo on/JVC's TBC off etc...
As an alternative, have a look here if anyone has had a similar problem:
http://forum.canopus.com/
Hope this works out.Cole -
Originally Posted by Cole
Thanks for your suggestion. Will give it a try. By the way my analogue footage is of top quality made on a professional VHS camera. Maybe, as you suggested, the TBC could be the culprit.
I wonder if Premiere simply captures the footage in DV without any compression or processing? I will give WinDV a try and see if the quality of the captured footage improves.Always try to make an informed choice -
Originally Posted by DNICE_ONE
Don't judge how it looks by what is on your monitor, convert and burn a few test clips to DVD and judge them by how they look on the TV.
best capture hardware and best results for capturing video 8 and later VHS
By mayhampixi in forum Capturing and VCRReplies: 2Last Post: 4th Jun 2011, 21:51 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
Capturing SWF Stream, Results in Taunting Server Admin Video
By smartwhois in forum Video Streaming DownloadingReplies: 1Last Post: 27th Jun 2008, 11:31 -
Capturing off Digital Converter box gives only so-so results.
By brassplyer in forum Capturing and VCRReplies: 3Last Post: 11th May 2008, 11:14 -
Premiere CS3 bad capture results
By LSchafroth in forum Capturing and VCRReplies: 6Last Post: 15th Mar 2008, 13:17
