I'm looking for a tool to do this. If you know of one, let me know!
Thank you!
MPEG Streamclip is able to export into very various containers, codecs etc., is also able to open vob files, but I didn't sa any "split" option.
Maybe it has something to do with the fact that I don't have the MPEG-2 Playback software from Apple? -
Use the slider and Edit > Select In / Select Out for start and stop position of a segment. Then Save As to save the segment. That's how I use it.Originally Posted by kaz219
Yes, I would think so.Maybe it has something to do with the fact that I don't have the MPEG-2 Playback software from Apple? -
I think it depends what you want to do with this split VOB file. If you are trying to create separate playable DVDs, then DVD2OneX is probably the right tool.
If you want to separate a movie and extras (or various episodes) and pull them out for editing, then something like Cinematize is probably the best tool.
The problem with MPEG Streamclip is that it doesn't know anything about the DVD structure, so it just views VOB files as gigantic movies without interruptions. If you have several movies or extras stuck together in a VOB file, then you would have to go hunting for them manually. If you have multiple angles or something like that, the situation is pretty hopeless. -
thanx, it was enough for my needs:
shift-move the cursor to select an area.
"x" deselect the selection
command-T trim the selection
"save as" and that's it.
AviSynth Script: VOB Splitting help
By PsyCLown in forum Video ConversionReplies: 15Last Post: 15th Apr 2012, 19:21 -
Splitting VOB files with audio delay/quality loss?
By S0VIET in forum Authoring (DVD)Replies: 8Last Post: 30th Oct 2010, 21:48 -
Splitting vob(mpeg)
By Peterrrrr in forum EditingReplies: 4Last Post: 17th Nov 2008, 12:24 -
Splitting and Joining then Converting VOB > MPG > FLV
By deportu in forum Newbie / General discussionsReplies: 7Last Post: 12th Jun 2008, 21:32 -
VOB editing before burning (splitting, chapters, etc)
By windranger in forum Newbie / General discussionsReplies: 7Last Post: 3rd Nov 2007, 08:29
