Hi,
I've an NEC DVD+-RW ND-6500A drive in a notebook,
http://www.nec.co.uk/DVD_RW_ND6500.aspx
max speed is 24x for CDs and 8x for DVDs. I've bought some Verbatim 16x DVD-Rs, if I try to burn data to these using the drive will I cause any damage and is it possible to upgrade the firmware to to increase the max DVD burning speed![]()
Your burner should write them at 8x.
He's a liar and a murderer, and I say that with all due respect. -
thanks steve!
yes, nero reports max 8x so it'll burn them at that speed, no harm done. Firmware is 2.40 which seems to be fujitsu-siemens specific as it's in one of their notebooks. There seems to be 2x and 4x firmare updates for the same drive available from NEC..
http://www.de.nec.de./softwareoverview2.php/id/1333
..you obviously can't upgrade 2.40 to 4.24, hence the warnings! Would a firmware upgrade allow for an increase in burning speed or is the max burn speed physically limited?
Regards -
Some discs do not do as well at slower speeds so you might want to check the burn quality. Most often +R discs do better at lower speeds. I also have had good luck with TY at lower than posted.
Still a few bugs in the system...
Verbation 16x and GSA-S10N drive
By webstar in forum MacReplies: 4Last Post: 23rd May 2010, 01:15 -
Cannot burn to a DVD disc and DVD RW-drive changed to CD-drive after copy
By coody in forum DVD & Blu-ray WritersReplies: 0Last Post: 13th Sep 2009, 05:18 -
LG GH22LP20 16X won't burn at more than 2X
By BeyondInvisible in forum DVD & Blu-ray RecordersReplies: 2Last Post: 3rd Feb 2009, 14:55 -
Should I burn 16x discs at 8x?
By sky captain in forum Authoring (DVD)Replies: 22Last Post: 19th Dec 2007, 22:58 -
I/O Magic DVD ReWritable 16X Drive Not running at 16X
By mmitsch in forum DVD & Blu-ray WritersReplies: 3Last Post: 7th Jul 2007, 00:40
