After capturing video via VHS, or live TV, the image looks great with the exception that any quick movement in the picture seems to result in "roughness" around the egdes of the image. For example, if a person is running across the frame of the picture, the outline of the person appears "jagged" or blurred a bit. In a frame where there is little or no movement, the problem does not appear visible. Is this what is referred to as interlacing? Looking at this web site, the problem looks like the third example on the page:
http://www.100fps.com/
I am capturing using WinTV2000 with a Hauppauge 350 PVR.
Questons:
Can I remove this interlacing effect on existing captured files?
Is there a way to reduce or eliminate this artifact all together?
Are the solutions listed on the web page I posted the best ways to handle this problem?
Interlacing is normal. A computer monitor does not interlace and that's why you see the rough edges. When you burn to a dvd and play on a TV screen, the image will appear normal.
Steve -
Thanks! Yes, I see that after burning and playing on the TV the problem no longer exists!
Steve: YOu wrote: "Interlacing is normal. A computer monitor does not interlace and that's why you see the rough edges" Does that mean there is no way to improve the picture quality regarding interlacing when viewing on a computer monitor? It's not horrible, but if there is some sort of program that could improve the picture re: interlacing that would be great!
For the computer the best solution is a deinterlacing video player such as PowerDVD or WinDVD. Often a reduced feature version of one or the other is supplied with a DVD player or a DVD writer. Check your CD.Originally Posted by dzachau
If all you wanted to do is watch on a computer, you could encode it progressive but that would seriously lower quality when played to a TV.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
Moving the "Run" command
By CSULB71 in forum ComputerReplies: 10Last Post: 8th Dec 2010, 19:07 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
Is this a video Codec issue? The videos have jagged/rough edges (PIC) Incl.
By Ricky_S in forum Newbie / General discussionsReplies: 11Last Post: 30th Sep 2009, 20:57 -
"Folds" along edges of objects after ripping to XviD
By udaykhan in forum DVD RippingReplies: 26Last Post: 24th Jul 2008, 00:19
