I have some AVI files that are DIVX encoded.
Basically the sound is out of sync, it starts off OK but seems to drift more and more the further into the file you get.
I use ffmpegx to extract the audio as a seperate track, and when I play it back it is the same length as the video file is, so I'm hoping/guessing that if I can combine the two into, say an mpeg, I'll have a video file with synced sound?
Am I pissing in the wind here, or does that sound right? I'm struggling to manage to do this with ffmpegx. I figure I need the Mux option but it doesn't appear to do anything (with 0.9.3t)
cheers,
Paul
Originally Posted by major
I'm wondering if the AVIs are corrupt as I've noticed that when playing them in VLC or Mplayer, although the file should be, say 30 minutes, if I try and seek to a point after 20 minutes or so, the video window simply disappears, yet if I watch the AVI from the start it plays the full 30 minutes, albeit with the audio corruption.
I did try the "Fix" option from the ffmpegx Tools menu and it creates a new file, but it appears to do the same thing.
cheers,
Paul
laserdisc capture: combining audio & video from 2 different players
By leslie80 in forum Capturing and VCRReplies: 3Last Post: 31st Aug 2010, 00:42 -
Combining video and audio files
By lbblock in forum Newbie / General discussionsReplies: 1Last Post: 10th Jan 2010, 10:17 -
Audio and Video not combining
By adeleander in forum ffmpegX general discussionReplies: 9Last Post: 23rd Sep 2008, 15:52 -
Combining Audio and Video in VirtualDubMod
By jwfc in forum Newbie / General discussionsReplies: 1Last Post: 30th Oct 2007, 21:13 -
Video with 2 Audio Streams TO mpeg1 with 1 audio stream
By Xenogear900 in forum Newbie / General discussionsReplies: 1Last Post: 5th Aug 2007, 19:00
