  1. Member mw2merc's Avatar
    Jul 2001
    Smog Capitol, California
    1st of all, I'm new to DVD 2 VCD/DivX conversions.
    I've tried several progies, and I have yet to find one that will SUCCESSFULLY extract without crashing. The DOS based ripping seems to generate errors like no tommorow.
    Is there a good GUI/Windows progie to do it?
    mw2merc
    "I put the KILL, in SKILL!"
    "faecs occurrere"
  2. Member xzarkad's Avatar
    Apr 2001
    Netherlands
    You might want to check out this site:
    http://www.flexion.org
    You'll probably find the guides and program you need.
    The Dutchman
  3. Do u want ac3 or normal stereo?
    Stereo:
    First of all, use smartripper to copy the dvd on your harddrive and then U can rip the sound of the vob-files with dvd2avi. Even a sample-rate conversion is possible on-the-fly.
