So I'm trying to convert a ton of my star wars game cutscenes to divx. There are ones with the extension .san (smush animation) and I can't convert them. I don't want to do screen captures because they're not that sharp compared to a direct conversion. I know about rad video tools and have used them to convert other star wars game clips to divx. But this type won't convert.
Anyone have a solution??? I could output it to my vcr and then dub it back on my wintv pvr250 but I'd prefer to avoid doing it twice in realtime.
Suggestions???
Results 1 to 12 of 12
Hmm... Any ideas???
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Do you have a Small File/Video you could upload So i can look at it,I never heard of (smush animation) before.
Thanks. I'm not sure which clip this is but here's one of the files.
longtime.san
I posted at a star wars forum and was told its pretty much impossible since these are embedded in the code and not run by a seperate video program like bink or smacker.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Oh ok. I figured since it was for gaming I'd leave it OT.
BUMP
So I was wondering if anyone knew of a converter for the Lucasarts .SAN files?????
My alternate plan is to use my video out on my video card and output it to my vcr to cap it then dub it back.
Another forum suggested I route it back directly to my capture card (wintv pvr 250). I'd like to do that but I was worried about audio feedback. BUT the wintv pvr 250 has its own audio input so I guess that wouldn't be too bad.
But what about system strain?? I'm running a 2.66ghz celeron with 512mb ram. If I run my recording software and then play my game at full screen while capping in dvd mode would that be too much????
Thanks for any tips.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
what do you use to open the san file
you could try using a screen capture program such as camtasia to record what is being diplayed on your monitor -
Yep thanks I've tried them a little.
What I'm trying now is to do a real time dub on the same computer using my wintv pvr 250. The only problem is the audio. Since its from the same computer it just gives a buzz. I'm trying to output the audio then bring it back to the audio input of the capture card. But I want to keep the synch in line. Ideas??Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Use the "TV-out only on PVR 350 / Disable Software Mpeg decoding" Registry hack for the PVR-250.
http://www.cask-of-amontillado.com/htpc.html -
Thanks but thats not quite it. I'm trying to record IN to my wintv from my video card OUT.
After trying for a couple of hours tonight I've pretty much resigned myself to outputting to videotape then redubbing it later.
And as for capping full screen DOS I don't think I'll ever be able to do it. At least not with my ATI Radeon 9250.
Thanks for all the suggestions.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Originally Posted by yoda313
You can get the same result by pressing the record pause button (the one on the little record drop down window) while recording. That doesn't pause the recording (as you might expect), it pauses the decoding and display in WinTV2000.
You can also use WinTVCap. It's a command line app that records from the PVR-250. Before I discovered the reg hack for the PVR-250 I used that program.
Really bad DivX's using "HD" mode in DivX Plus Converter
By sjdean in forum Video ConversionReplies: 37Last Post: 22nd Oct 2011, 08:31 -
"Any Video Converter" output format choices - can anyone explain?
By slipkid in forum Video ConversionReplies: 5Last Post: 14th Feb 2009, 17:09 -
Converter box use and horizontal "waves" in picture
By anet in forum DVB / IPTVReplies: 15Last Post: 16th Jan 2009, 18:42 -
how to create "letterbox" bars with Total Video Converter
By zomigi in forum Video ConversionReplies: 6Last Post: 31st Jul 2007, 09:47 -
Choppy "Strobe" results on Divx Converter
By kirklt in forum DVD RippingReplies: 0Last Post: 28th Jun 2007, 23:36
