Is component video much better that s-video when attached to a HDTV?
I'm considering an ATI x700 pro, but have not found out for sure that it works or how much difference it will make.
Has anyone tried it or know of a better way to get component video?
I don't really care about the video capture.
If you have HD on your computer and want to view it on you TV then YES you want component but if you are just going to view standard def then all you need is 'S' video.
bits -
S-Video (Y/C) is standard definition interlace with NTSC or PAL encoded color.
Analog component can be standard definition interlace, standard definition progressive (e.g. 480p), high definition interlace (e.g. 1080i) or high definition progressive (e.g. 720p).
In each case analog component uses separate full bandwidth luminance and color components.
Note that none of these are compatible with the future HD DVD player. In that case you will need a DVI or HDMI output that supports HDCP encryption.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I use a ATI chipset Radeon 9550 video card on my multimedia computer. It's a fairly inexpensive card with DVI output. I run that through a ATI DVI to Component converter to my video projector. It gets a much better picture than S-video. With S-video printing was mostly illegible on the screen. With component it was easy to read. Check the ATI website for compatibility with video cards. It mostly works on the Radeon series.
I agree for the current cards. Here is the adapter FAQ.
http://www.ati.com/products/hdtvadapter/faq.html
Next generation ATI cards will include hardware decoders for various MPeg4 HDTV including h.264 and VC-1.
http://www.ati.com/technology/h264.html
For now I'd buy a card like the 9550+adapter and wait for a future generation that supports full hardware HDTV decoding.Recommends: Kiva.org - Loans that change lives.
I decided to go with the Radeon 9550 video card like redwudz has. The picture is better and I can squint and read the text, but I would like some info on tweeking it. Does anyone know of any sites? ATI doesn't have much info.
Thanks, Chester -
Your HDTV is the main limitation.Originally Posted by chester-proudfoot
TV Model Number?
Resolution settings you are currently using for card?Recommends: Kiva.org - Loans that change lives.
Intel GMA HD/Core i3 - VGA has TV-out/S-video-out/component-video-out?
By Morality124 in forum Media Center PC / MediaCentersReplies: 5Last Post: 9th Jan 2011, 01:44 -
RCA composite video on Wii but component video and VGA inputs on tv
By shashgo in forum Newbie / General discussionsReplies: 3Last Post: 22nd Aug 2010, 22:48 -
Component to S-Video Converter
By MasterOfPuppets in forum DVD & Blu-ray RecordersReplies: 6Last Post: 31st Jul 2010, 09:27 -
Compatibility of composite video output VCR with component video input TV
By boshu22 in forum Newbie / General discussionsReplies: 7Last Post: 7th Sep 2009, 23:46
