VST Plugins are high quality sound processing modules used in many commercial audio editors. The difficult part has been finding free apps which can load VST plugins. Audacity has a module, but it isn't ready for prime time.
Christian Budde has developed a VST interface for Winamp which works nicely.
You can get it here:
http://www.kvraudio.com/get/1946.html
Here's a few dozen free VST plugins to get you started. Start with the 1 Knob Compressor below, as it is, well, 1 Knob
http://www.betabugsaudio.com/dl.php?id=1 1 Knob Compressor
Another set which is highly recommended are the DigitalFishphones Fillet Pack http://www.digitalfishphones.com/main.php?item=2&subItem=5
The other 80+ free VST audio enhancer plugins:
http://www.kvraudio.com/get.php?mode=results&st=adv&soft=e&type%5B%5D=19&type%5B%5D=23...&sort=2&rpp=45
* Using the disk writing plugin that comes with Winamp, you can easily save your enhanced file to .WAV then convert to .AC3/MP3/MP2 with your app of choice.
__________________________________________________ ____________
Here's an MP3 audio example. I'm punching the plugins in and out, you'll hear the first group at :20 for ten seconds, then I put in various groups of filters at 5 second intervals. Most of them are various limiters and spectral exciters, plus bass enhancers and stereo wideners.
vst-example.mp3
Results 1 to 1 of 1
Enhancing Audio Volume in Video
By redevil01 in forum EditingReplies: 4Last Post: 29th Oct 2021, 10:00 -
Any multimedia player that supports VST plugins?
By MarcMiller in forum Newbie / General discussionsReplies: 5Last Post: 14th Nov 2011, 17:41 -
FREE transition plugins for Premiere pro cs3
By mudh in forum EditingReplies: 0Last Post: 14th Oct 2011, 17:00 -
Mini Guide - Using Audacity With VST Plugins
By Soopafresh in forum AudioReplies: 19Last Post: 17th Aug 2011, 21:13 -
What are the best free audio editing tools with VST support?
By babypotato in forum AudioReplies: 7Last Post: 18th Jul 2011, 00:00
