Everytime I use TMPGEnc for Encoding an avi(divx) file,is there an error message:
Illegal floating decimal point calculation order.
open the avi in vitualdub hit the scan forwar button at the bottom. keep hitting it at the same tim watch the bottom of the window when you see a frame error showup step back 1 frame and put a selection starting point hit the alt key this will get rid of the error at the bottom hit the scan forward button and the alt key till the error doesn't show up any more move forward 1 frame and put a selection ending point and delete the bad frames make sure that it is set for direct stream copy and save the avi. you may want to scan it again if ok you will also want to re rip the wav if you are doing that aswell.
note: if tmpgenc locks up again look at the time it died that will give you a starting point for virtualdub also if you have to delete too many frame you may want to rethink useing the avi -
When I use Virtual dub i get this warning message:
Warning:Virtual dub has reconstructed the index of this file,but you have not specified rekeying in the extended open options dialog.Seeking in this file ´may be very slow
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
TMPGEnc to License x264 Encoder for TMPGEnc 4.0 XPress
By poisondeathray in forum Latest Video NewsReplies: 17Last Post: 28th Jan 2011, 15:07 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
