Hi,
I need some help converting some movies made on a Sony Video 8 film to my computer so that I can edit them. I'm new to all of these, so please bare with me.
The files (I think) are in a standard DVD style as they are .Vob files but most programs don't accept these. For the time being I have been using Microsoft Movie Maker as it was on my machine, but this will not accept the .Vob files, so I guess I need to convert these first.
Can anyone please suggest an easy way to convert the files to a suitable format, and which app should I really be using to edit the files?
Many thanks in advance,
-Graham
Refine the question.
Sony doesn't make "film" but they have 3 8mm videotape formats (named 8mm, Hi8, Digital8).
You have files? How did the material get from tape to files?
VOB files usually come from a DVD authoring project. VOB files contain MPeg2 material. MS Movie Maker will not edit VOB files.
Answers to these questions will help steer an overall answer.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Sorry, let me explain...
It's not actually me doing this, it is my uncle and as he although he is fairly computer literate, there are a few gaps in his knowledge.)
He got the files off of his camcorder using some software called Pinnacle (version 9). I haven't seen this, so I'm not 100% sure what it does but I guess it created a DVD from the files.
Does that help?
-Graham -
Originally Posted by GRussell31
Now we need to know what you want to do with the edited files. If a DVD is the goal, then you need a program or set of programs that will do these steps.
1. Demultiplex (or extract) MPeg video and audio from the VOB file. If the audio is AC-3 then you need a program that will decode that.
2. Edit the resulting MPeg video and audio.
3. Re-encode the edited video into DVD compatible MPeg2.
4. Author the DVD (menu creation, remake VOB, BUP, IFO files)
5. Burn the DVD
Many options exist (see tools). You could use a product like Pinnacle Studio or ULead Video Studio 9 to do all of the above. ULead has an optional decoder for AC3 audio.Recommends: Kiva.org - Loans that change lives.
film festival requirements (SONY HDCAM)
By templedog in forum DVB / IPTVReplies: 33Last Post: 22nd Feb 2013, 22:16 -
not converting complete film
By idolgolf666 in forum Video ConversionReplies: 2Last Post: 13th Feb 2011, 09:58 -
Converting video to MPEG2 for Sony Bravia TV
By Teufelshunde in forum Video ConversionReplies: 7Last Post: 6th Jan 2011, 10:39 -
Film capture issue - partial film frames on a video frame. Why?
By brassplyer in forum RestorationReplies: 14Last Post: 27th Apr 2010, 16:14 -
Converting video for Sony Ericsson W950i using ffmpegx
By Chris_D in forum ffmpegX general discussionReplies: 4Last Post: 24th Aug 2008, 07:19
