I have a few Lost season 2 HD Transport Streams that are broken up into 145Mb pieces. I'd like to join them together for better viewing. Any suggestions?
I've tried the "Split & Concat" program without success and I've searched this forum with no results.
Any help is appreciated!
	MPEG Streamclip can join MPEG files.
 The joined files must have the same PIDs, the same start codes, and the same audio/video properties (that is, they must come from the same source or channel).
 Using "Convert to MPEG" before joining the files can be helpful, because it changes PIDs and start codes to a default value.
 The preferred method to join streams is to Copy one stream in MPEG Streamclip, open another stream and Paste it there. This method checks that the joined streams indeed are compatible.
 Another method is to put the joined MPEGs in the same folder, and rename them so that they sort as desired in list view. Then select them via MPEG Streamclip's "File/Open Files..." dialog box (Shift- or Command-click to select multiple MPEGs). Then choose "Edit/Fix Timecode Breaks". After this MPEG Streamclip should report the combined length of all MPEGs (check the Log Window if you want to know whether any timecode breaks were found). Then choose "File/Convert to MPEG..." to save them in a single file. If the video transition between two files looks bad, you can use the Cut command to improve it. You can join very different and incompatible MPEGs with this latter method so the end result is not guaranteed to work.
	Very detailed answer! Thanks! I'll give it a shot and report back. Thanks again!
	Another alternative is NullPacketStripper, but I think while joining the transport streams, it also strips out null packets, which programs like VirtualDVHS2 need to play back the transport stream properly.
  Combine two transport streams.By Deadeditor in forum Newbie / General discussionsReplies: 0Last Post: 13th Apr 2011, 09:12
  Seeking in Transport Streams(.TS)By deepp in forum ProgrammingReplies: 0Last Post: 15th Jul 2010, 17:00
  Joining transport streams ?By NotSoEasy in forum DVB / IPTVReplies: 7Last Post: 3rd Jul 2009, 19:32
  New experimental TS cutting software for MPEG-2 and H.264 Transport StreamsBy Nukster in forum EditingReplies: 2Last Post: 14th May 2009, 10:16
  European transport streamsBy branch in forum DVB / IPTVReplies: 26Last Post: 27th Mar 2008, 04:50
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Visit Homepage
				Visit Homepage
