I have a .mp2 file which has an usually low pitch to it (makes the male voices sound like they're on steroids). Is there an easy/free way to raise the pitch? I'm only a casual video/audio editor but not a complete noob.
You could drop it into VirtualDub Mod, save out the audio as a WAV, then put the audio into Audacity and change the pitch there. They're both freeware programs.
When you change the pitch, you may also change the length, which may result in audio/video sync problems. But you likely have those anyway is the pitch is wrong.
If you get the sync right, you put the WAV file into a program such as ffmpeggui and convert it to AC3 audio, if that's what you want, then mux that back with the video.
It's not hard, just a bunch of steps to go through.
EDIT: I misread that. You already have the separate audio file. Just put it in Audacity and follow the rest of the method. But note the part about sync is you are joining it back with a video.
Easy tool to change audio fps
By davidbowie in forum AudioReplies: 20Last Post: 17th Jul 2014, 04:23 -
Audacity no pitch change
By ranosb in forum AudioReplies: 21Last Post: 15th Sep 2012, 21:56 -
Change font size... Is there an easy option?
By damian5000 in forum SubtitleReplies: 3Last Post: 17th Jul 2011, 20:30 -
After ripping bluray to mkv, is it easy to change the audio?
By AndyD in forum Blu-ray RippingReplies: 5Last Post: 26th Sep 2010, 20:24 -
:?: half-speed play with no audio pitch change?
By gregconquest in forum Software PlayingReplies: 8Last Post: 10th May 2008, 22:21
