I've learned tons just reading other peoples advice on here but have run into a wall on this one.
My problem is this. I captured an old VHS video using an S-Video connection. captured a V-Bitrate 7000 and the "raw" footage looks as good as the original. When I bring it into Mediastudio 7, do my stuff to it and go to create my file, my finished product comes out lower quality, mainly more blurry. I made sure I matched the format (MPEG 2) and didn't change the bitrate. I've tried 2 pass encoding, no de-interlace, and a 100 other suggestions I found on here. I'm sure the answer is somewhere here.![]()
When you get to the Create Video stage, make sure that Use Smartrender is checked. Only anything that has changed during your editing (transistions, titles, etc) will be re-encoded, the rest will be untouched so the quality cannot change.
How we can remove commercials from a video cd without loosing quality.
By nusratjaveid in forum EditingReplies: 1Last Post: 4th Dec 2010, 10:17 -
remove a logo without loosing quality
By mathmax in forum DVD RippingReplies: 13Last Post: 9th Jul 2010, 11:54 -
Vegas 9, and HD hero. Loosing too much quality rendering, need help.
By carl1864 in forum EditingReplies: 3Last Post: 26th Mar 2010, 15:54 -
How to get AVCHD on Harddrive of PS3 without loosing quality
By alex1357 in forum Video ConversionReplies: 2Last Post: 7th Jun 2008, 10:06 -
What to use to edit DVD (Video-TS) without loosing (much) quality.
By Scav2003 in forum MacReplies: 2Last Post: 2nd Nov 2007, 10:39
