I have an avi file which seems to have two people talking at the same time saying the same things except in a different voice. I wanted to know if I could edit the audio so I can take out one of the voices.
Is the audio in stereo and is one voice on the left and the other on the right? Adjust the L-R balance to check.
If the answer is yes to the above then it can be fixed and I can give you more info pending your reply."Art is making something out of nothing and selling it." - Frank Zappa -
Other possibilities are that it has two audio streams and your player doesn't properly handle multiple streams, so just plays both or that it is one stream with both languages over both channels in which case there isn't much you can do.
Perhaps an AVI you have contains two audio streams. You need just remultiplex your file and leave only one audio.
AVI with AAC audio to AVI with MP3 audio
By Neroon in forum Video ConversionReplies: 6Last Post: 30th Jun 2010, 09:15 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 16:38 -
Dual audio AVI to singl audio AVI.
By Benhermies in forum EditingReplies: 8Last Post: 20th Aug 2008, 21:44 -
Converting an AVI video with AC3 audio to an AVI video with MP3 audio
By rijulHKG in forum AudioReplies: 1Last Post: 15th Jul 2007, 01:23 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 5th Jul 2007, 00:22
