ok for awhile i had trouble reading dvd+rw's for some reason but now seems to be working alright, the problem now is that for some reason i cant erase my dvd+rw's? when i try to format, says its read only? and if i try to use a program like nero or sonic it acts as if theres no disc in the drive to be erased? can anyone help me
also when i go to sonic and go to disc information, the dvd+rw disc is a single layer dvd rom, closed, data
but when i put a blank dvd+rw in thats exactly what it says it is
so am i unable to rewrite the disc because of what i burned to it? im confused
how did my rewritable turn into a single layer dvd rom, which i cant write over?
thank you
wow... no help from me... but to let you know i had the same problem with my cyberhome 1600 after i upgraded the firmware. I even tried erasing it in windows XP always came up read only. very strange. i am hoping someone has that answer. or can guide to the answer if it is in a previous post.
thanks all guys.
Problems with Philips +R DL discs
By carlmart in forum MediaReplies: 17Last Post: 29th Sep 2010, 08:24 -
Philips DVP5990 Hack problems
By bikey in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Aug 2010, 11:44 -
Can Philips 5990 firmware be used on Philips 5992 Dvd Player
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 17:06 -
Philips dvdr3360h problems
By rooboy in forum DVD & Blu-ray RecordersReplies: 1Last Post: 4th Oct 2007, 11:25 -
Problems with philips dvd-622
By angelarumble in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Jun 2007, 14:38
