Hi,
I read the newbie guide for getting an mpeg on one disk but I am having problems!
I have already converted this movie from an .avi to mpeg using TMPGEnc 3 express. (TMPGEnc 2.5 didn't recognize the audio.) I lowered the bitrate to around 800 I think.
The resulting mpg file size in now only 698MB but Nero won't let me burn it. It says it isn't in the right format and will have to re-encode which will make it is too big (824MB)
I am now using TMPGEnc 2.5 to try and reduce my mpg to fit on one 80min disk. I have a template saved for VCD on one Disk, when I load the template through the wizard and get to point where it should let me resize the video it the bitrate jumps up to 2000 and won't move down any. I can't even use the slider to reduce bitrate or use the settings.
Can anyone help me to get this thing onto one disk please. I'm useless!
Results 1 to 9 of 9
In Nero, when you open it and select VideoCD, you see the box that says "create standard compliant cd" ? Uncheck it. Then it should allow you to load your 698 mg movie without reencoding.
- or -
In tmpgenc, you really shouldn't use the wizard, but if you insist....
Load it as you normally do, get to the last screen and uncheck the box that says to start encode automatically (you don't want to do this). Once you're back to the main screen hit the load button> extra folder> unlock template. Then go into settings and change the biterate to whatever you want. Then hit start. -
http://members.dodo.net.au/~jimmalenko/TMPGEnc1CD.htm might help.
You might also want to look at VCDEasy, which is highly regarded in the VCD Authoring stakes.
EDIT:
Fixed link
If in doubt, Google it. -
Link is dead. You mean this: http://members.dodo.com.au/~jimmalenko/TMPGEnc1CD.htm
:P
Who said 'dat?Originally Posted by jimmalenko
I was here first.
You're following me!
:P
I suddenly got a case of deja vu.
Yeah, but, it doesn't even matter... 8)Originally Posted by jimmalenko
Don't know who's following who! But I did mananged to follow the help you left. Unchecked the complient VCD thing and it burned fine.
Thanks very much!
Red
Fit to disk in AVStoDVD?
By Des in forum Video ConversionReplies: 7Last Post: 3rd May 2010, 23:36 -
TMPGEnc resize problem
By Vatrik in forum Video ConversionReplies: 17Last Post: 15th Mar 2010, 07:27 -
how to fit a 7gb mpg to a 4.7 dvd?
By just in forum Newbie / General discussionsReplies: 4Last Post: 25th Oct 2008, 05:38 -
Resize xvids to fit a widescreen TV
By DrSteve in forum Video ConversionReplies: 7Last Post: 28th Jan 2008, 10:45 -
What authoring programs offer fit to disk using .avi files?
By dang in forum Authoring (DVD)Replies: 2Last Post: 16th May 2007, 22:05
