Closed Thread
Results 1 to 13 of 13
  1. i used your search engine to find a form on this but could not. i hope this the right form. i have several 80mb avi files that i'm trying to convert and burn to a dvd. i'v converted them with tmpgenc.convermovie.dvdsanta.and vso divx to dvd. they all converted and i burned the files to dvd. but i get very bad quality. so my question is am i trying to do something that can't be done or am i doing it wrong? i'v converted them to 720x480 4400 and 4800 khx and 16:9 and 4:3 and they all come out bad quality. is there a guide i can use to do this. thanks for any and all help.
    He Who Hesitates Is Lost.
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    "80MB AVI files" doesn't exactly tell us much about your files, except that they're 80MB and they're video in an AVI container
    Without the basic information about your source (info from GSpot or AVICodec), we're all pretty much guessing as to where you're going wrong. I'm guessing that they're probably 320 x 240 and so when you're converting to 720 x 480, that's one good reason why they're bad quality.
    http://members.dodo.net.au/~jimmalenko/AVI2DVD.htm might assist.
    If in doubt, Google it.
  3. what software do i use to copy gspot and post it here. your right about the 320x240. i'll get you the rest of the imformation as soon as i can. thanks for the fast reply.
  4. Member yoda313's Avatar
    Jun 2004
    The Animus
    You can make a screen shot by using the alt+prnt scrn snapshot feature of windows. Then upload the saved jpg (by pasting it in microsoft paint or an editor of your choice).
    But you can edit out the title of your video. We only need the statistical information. (upload the file in the file upload section at the bottom of the posting screen - though be sure the filename doesn't have any spaces in it)
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    How do I upload screenshots ?
    It's a sticky in Newbie/General
  6. again thanks for the quick reply. if i did this right i should be uploading a shot of gspot. if it comes throug maybe you can tell me what i need to do.
  7. well i see that did'nt work. i'll go back and see what i did wrong.
  8. You are in breach of the forum rules and are being issued with a formal warning.
    / Moderator lordsmurf
  9. Member kush's Avatar
    Jul 2004
    Near "Pacific Park", USA
    The results are trash because your source it lousy..Look @ the 'kbps' in your screenshot...168?...WAY too low to bother. The frame size..Asking 352x192->720x480 is too much to ask of even the best resizing filters, let alone an AIO tool..And the audio..48kb - must sound like a scratchy tin can.
    Remember kids, you can polish a turd, but in the end you've still got a turd.
    :P
  10. ya may wanna edit the name outta the top of the window as well and reupload (just tryin to keep ya outta trouble) but yea, thats a really lousy quality file, it wont look very good no matter how you slice and dice it....
  11. ok thank for all the help. i'v never seen one like this before. i'll just delet it.i really appreceat all the help. i'll see if i can upload the gspot again and black out the top name. again thanks for all the help.
  12. LOL, YOU MAY WANNA DELETE THAT ONE TOO....block out the names on BOTH parts..........but yea, your gonna want a better source if you want to have decent end results......
  13. Video Restorer lordsmurf's Avatar
    Your source material is crap. It's also warez.
    Go buy the DVDs. They were released in 2001 or 2002.
