I am transferring a video to disc for a friend who does not have a PAL SVHS deck, and want to split the "raw" DV AVI over a number of discs so he can work on it himself. What do I need to set the max AVI size as to split at 4 GB?
Thanks.
I assume you mean WinDV? You will get about 13Gb an hour with DV, figure roughly a third of that for a 4.37Gb DVD. If you set the maximum AVI size (frames) to about 36000, that should get you close. That's about 20 minutes per DVD of video. Try it and adjust as needed.
The setting information is here. http://www.dvd-guides.com/content/view/33/59/
Don't trust my math too much, it's late here.
VFW ffdshow Settings to Edit flv in Vdub
By kaskaļ in forum Newbie / General discussionsReplies: 15Last Post: 1st Jun 2011, 12:40 -
How can I edit cedocida codec settings in windows 7?
By dssdss in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 9th Sep 2010, 03:10 -
any software to edit and add different settings on 1 video? to diferent sce
By kopmjj in forum RestorationReplies: 7Last Post: 5th Apr 2010, 22:41 -
If you want your topic in Google, don't edit the subject line
By jimdagys in forum ComputerReplies: 0Last Post: 25th Sep 2009, 05:27 -
Edit VM Commands and UOP & Settings Question [DVDLabPro]
By urdivine in forum Authoring (DVD)Replies: 20Last Post: 23rd Sep 2007, 16:44
