1-pass
multipass 1st pass
multipass Nth pass
what different btw the 3 above and when i need to use one of them ? i use the Virtualdub to encode the DVD to avi so which of the 3 options above i need to pick ?
thanks people
Any. The more passes (up to a limit) the better quality at a given bitrate.
You either go "1-pass" only, or "multipass 1st pass", followed by 1-n "multipass Nth pass".
/Mats -
1-pass uses ........ 1-pass. Cannot get any simpler than that.
multipass 1st pass is used 1st when you want to do a 2 (or more) pass encode.
multipass nth pass is used 2nd when you want to do a 2 (or more) pass encode. It must be done after a multipass 1st pass encode, and can be done any number of times after this. The first time you do this you are actually doing the second pass overall, so this is why it's call 2-pass encoding. You can do as many multipass nth pass encodes as you wish after this, with the next one you do meaning you are doing 3-pass encoding, and so on ...
http://download.divx.com/guides/QuickStart-EN.pdf
While 1-pass mode is fast and particularly suited to certain situations, multiplass encoding offers more consistent quality by allowing the encoder to first analyse the entire video before encoding it.
Some more reading:
https://www.videohelp.com/forum/viewtopic.php?p=1373870#1373870
http://speeddemosarchive.com/yabb/YaBB.pl?action=display;board=other;num=1126861122;start=0#10
http://forum.doom9.org/showthread.php?p=457101#post457101
http://www.divx-digest.com/articles/divx6_setup.html
Google is grrrreat !
If in doubt, Google it.
What is divx and xvid codec?
By Azrail in forum Newbie / General discussionsReplies: 4Last Post: 5th Oct 2010, 21:31 -
ffdshow audio filter config
By THX-UltraII in forum Software PlayingReplies: 0Last Post: 17th Feb 2009, 03:12 -
Is there a free DivX codec for Dr.DivX?
By Djard in forum Newbie / General discussionsReplies: 1Last Post: 10th Feb 2008, 03:33 -
Router config (D-link)
By SE14man in forum Newbie / General discussionsReplies: 4Last Post: 9th Dec 2007, 07:12 -
Best free DIVX codec?
By DonGallego28 in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2007, 18:45
