i'm a newbie sorry if i piss you off mods asking the same question againi have downloaded a documentary which is in english but it has Portugese commentary i tried to demux using virtualdub mod but i ended up with only one audio file..
moreover itsn't showing dual audio stream in the stream list only one list... i don't know what to do? plzz help me i want to get rid of the Portugese commentary i checked earlier posts and tried but nothing worked.. so kindly help me.. thnx alot in advance..
Each of the stereo channels has an audio track. Remove one by putting VirtualDubMod into Audio Full Processing Mode, then pick Audio Conversion and select either the left or right channel.
How to stretch longer audio stream to a shorter video stream ?
By ralf07 in forum AudioReplies: 9Last Post: 31st Aug 2011, 23:42 -
How Could I change the default audio stream in a Dual or Multi Audio AVI fi
By worldperseus in forum AudioReplies: 3Last Post: 17th Jan 2011, 06:53 -
encoding with DTS audio stream - Audio not found in AutoGK
By extrabyte in forum DVD RippingReplies: 1Last Post: 7th Jan 2009, 17:42 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 05:12 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 04:27
