I'm using DVD Architect 2 with the latest updates. They've added a lot of features since DVD Architect 1. I've learned how to use most I think. However, there's one thing I haven't figured out. And it may be because it can't do it. But I thought I'd see if there were any DVD-Architect guru's here who can tell me if this is possible, and if so, how.
What I want is to have two videos on my main menu. So that each can be played separately. However, I also want to include a third button that will play first the first one, then the second. Can this be done? If so, how?
I know how to make a video link to another video when it reaches the end, but as far as I can tell, this means anytime that video is played, it will then go to the other one. I want it to come back to the menu, unless the third "play all" option is selected, then in that case it will link to the other video rather than going back to the menu.
Again, can it be done? if so, how? Thanks in advance for any input.
Well think faster already....
No, just kidding, take your time. I really appreciate any help.-Tevya
Start WordPress -
This is something that can be easily done with PLAYLISTS. Don't know if v2 supports playlists, I've got v3.0c and just finished a big project that used them nicely.
Scott -
-if version 2 does not support playlists you can try this: you MIGHT achieve what you want to do, adding 2 menus, same buttons, same text, etc... but 2 menus playing 2 different movies. Check out number one - it shows how to link the buttons; number 2 shows where the green marker must be positioned.What I want is to have two videos on my main menu. So that each can be played separately. However, I also want to include a third button that will play first the first one, then the second. Can this be done? If so, how?
Will it work? Any other ideas? -
Dangit guys! I'm an idiot. I actually have DVD Architect 3c. I guess I was thinking ver 2 because this is the second version I have owned/worked with, but there was a version before I first purchased it. Sorry for the confusion. Okay, how do I do this playlists thing? I know I've seen it, but I haven't really used it.
Blu-ray PopUp Menu with DVD Architect Pro 5.2?
By dabezt in forum Authoring (Blu-ray)Replies: 0Last Post: 27th Apr 2011, 03:02 -
DVD Architect Pro 5.0 - Problem with Menu launch
By stealers in forum Authoring (DVD)Replies: 0Last Post: 3rd Jan 2009, 11:36 -
automatic chapters menu in DVD Architect
By exon in forum Authoring (DVD)Replies: 0Last Post: 18th Aug 2008, 10:10 -
Menu transitions/effects with Sony DVD Architect Studio
By sir_rob in forum Authoring (DVD)Replies: 9Last Post: 25th Jul 2008, 20:24 -
sub-menu problem in DVD Architect Pro 4.5
By younso in forum Authoring (DVD)Replies: 9Last Post: 3rd Jul 2008, 17:51
