I couldn't figure out what is the delimiter to search for a chain of characters as is.
For instance, looking for:
MP4 to AVI
I tried this sentence like it is above or I tried "MP4 to AVI"
The result is the same and the search result is each single word is found separately from the others.
Also, I could not figure out how to use AND OR NOT that are underlined.
How could I use it ?
Is it possible to enter an underlined word in the search field ?
I tried: AND and "AND" "and"
Nothing works.
You can't use ".
Click on advanced search and select search for all terms if you want and.
Or use google to search our site and you can use ",+,-.
https://www.videohelp.com/search -
OK, the search for all terms, I already tried.
It's giving me a zillion of matchs.
I gave up.
But the google search is a good one.
Thanks.
forum search cuts off @ November 2005?
By lordsmurf in forum FeedbackReplies: 2Last Post: 13th Nov 2009, 03:58 -
Search Excel Spredsheet Data in Vista Search
By mn072065 in forum ComputerReplies: 11Last Post: 29th May 2009, 00:26 -
'Tis the season to post stupid questions...
By lordsmurf in forum Off topicReplies: 23Last Post: 22nd Dec 2008, 19:14 -
Improve search function on forum
By cd090580 in forum FeedbackReplies: 0Last Post: 2nd Aug 2008, 09:59 -
Forget the OS: Mac, Linux, Windows, ?,,, It's the Desktop Search stupid!
By SpectateSwamp in forum Off topicReplies: 2Last Post: 20th Jun 2007, 14:14
