Trying to convert some MP4 coming from Handbrake to AVI (DivX) files (I do not have the DVD anymore).
The process runs fine. But the resulting file has no audio ...
There is bunch of threads about similar problems but I did not find any satisfactory answer to this one.
I have the same problem trying to convert an HD movie from apple's homepage to an avi divx file (my Pinnacle ShowCenter accepts only avi files). But there is no sound. I tried out all settings, without success.
Has anybody an idea how to convert this movie
http://images.apple.com/movies/us/hd_gallery/gl1800/nasa_shuttle_m720p.mov
Thanks Major for your answer.
But could you be more specific about "use it as external audio" ?
I have got myMovie_noAudio.avi
I have got myMovie.wav
Do you mean I should mux them together with FFmpegX ?
I tried it with:
Select multiplexing options
Mux as: AVI + audio
Resulting in a very fast job with nothing created.
Process Information:
built on Jan 7 2005 02:34:06, gcc: 3.3 20030304 (Apple Computer, Inc. build 1666)
I also tried it with:
Mux as: AVI
Resulting in another fast job and myMovie,wav.mp3 size 0 created.
Process information:
ffmpeg version 0.4.9-pre1, build 4736, Copyright (c) 2000-2004 Fabrice Bellard
configuration: --enable-mp3lame --enable-gpl --disable-vhook --enable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-amr_wb --enable-pthreads
Error while opening codec for stream #0.0 - maybe incorrect parameters such as bit_rate, rate, width or height
Wow !
I feel stupid not having seen this one "add audio" field at once.
It did work to create an AVI file that I can play on my Mac.
But still, it is not a format that my ARCHOS AV700 can read. Worse, it freezes it.
Playing around with the tools I found one way that works for me:
myMovie.mp4 --> VLC streamout --> myMovie.avi --> FFmpegX --> myMovie.avi (DivX)
For some reason I could not use VLC directly.
I could not find a way to streamout in the good AVI-DivX format with it (even though if VLC is able to play this format).
But this is another forum problem.
The "add audio" field has been very helpful however.
It solved a problem I had in this thread:
https://www.videohelp.com/forum/viewtopic.php?t=278843
Converting MP4 to AVI - Confusing Audio Problem
By visibility in forum Video ConversionReplies: 4Last Post: 29th Aug 2010, 18:02 -
Audio/video out of sync after converting (avi to mp4)
By Foxy Gogo in forum Video ConversionReplies: 1Last Post: 10th May 2010, 13:13 -
Converting Divx-AVI to MP4 - Output size option doesn't work
By tomzero in forum ffmpegX general discussionReplies: 6Last Post: 20th Mar 2010, 08:30 -
Blank video when converting MP4 to AVI DivX
By vidnov in forum ffmpegX general discussionReplies: 16Last Post: 12th Mar 2010, 18:45 -
Converting AVI (DivX/XviD) to MP4/MOV/3GP...
By JaleAlbatros in forum Video ConversionReplies: 5Last Post: 23rd Jul 2009, 18:51
