When I make a dvd with the new release the menu is very "sticky" in both Power dvd and my standalone. The problem on my pc is it almost freezes everything up with very slow and jerky mouse movements while the menu is playing. While playing the movie itself, there is no such problem. On my standalone, it takes about 10 seconds to move to the next titleset on the menu (I had several titlesets). Fortunately I had an older copy lying around here on my HD (version 2.0.2029.16323) and it encodes the menu just fine for me. Is anyone else having this problem? I would like to use the new additions like custom matrices but unfortunately I can't.
Is it an audio menu? If so have you tried the "Encode video to audio duration" setting? Or have you tried with no audio or a different audio file? If it is not an audio menu or the above doesn't work, can you email me & we can do some diagnostics offline?
It is an audio menu and I haven't tried the "Encode video to audio duration" setting. I'll try what you suggested and get back to you. Thanks for the reply.
I tried the "Encode video to audio duration" setting and everything is fine now. Thanks CB.
Problem with fresh PC system build - unusual instability
By PartingShot in forum ComputerReplies: 24Last Post: 6th Oct 2010, 20:36 -
DVDAuthorGUI: Menu problem
By videohalp in forum Authoring (DVD)Replies: 5Last Post: 20th Aug 2008, 21:11 -
FAVC Menu Problem
By marioval in forum Authoring (DVD)Replies: 1Last Post: 6th Feb 2008, 05:05 -
Movie Collector 5.2 Build 5 problem
By logannsan in forum ComputerReplies: 0Last Post: 3rd Oct 2007, 18:53 -
Menu Problem - Skipping
By vinnyv07 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 30th May 2007, 19:17
