Hi to all looking hopefully an easy one for to put me straight on,
Downloaded an Xvid movie burned to cd-r as data disc fine plays great excellent quality but a bad frame movement on it not a smooth running of the film really annoying to watch like a jerking movement.
Now it does the same when played in Windows media player but to be fair seems to plays ok in VLC player.
Now you may say windows media player does not have the correct codec for it but in my standalone its the same frame problem.
My standalone plays Divx as well as Xvid and I've since downloaded another Xvid which plays fine in windows media player nice and smooth and also in my standalone.
So I guess I want you to say that the problem is the Xvid and the way it was encoded rather than anything I have done wrong?![]()
Closed Thread
If you download videos from the net you takes your chances are far as quality of the encode is concerned. It might have originally been a PAL movie converted to NTSC or vice-versa. This could introduce stutter. It might have been encoded from 23.976 to 29.976, in which case etxra frames have to be created and can cause stutter. Many things can go wrong when you don't know the source.
Read my blog here.
Many standalone players have problems with packed data stream Divx/Xvd videos. To fix you have to unpack them and sometimes change the header. However, given that you have problems in Media player as well, chances are the encode is at fault.
You really should not be discussing downloaded videos on this site. I'm sorry but I have to lock this thread.
Smooth frame by frame accelerated video playback?
By Malachaidc in forum Newbie / General discussionsReplies: 10Last Post: 30th Jul 2012, 12:40 -
How to cut xvid avi by a non-key frame
By Kirill in forum Newbie / General discussionsReplies: 2Last Post: 2nd Aug 2010, 07:52 -
Standard XVID Frame Sizes
By adalect in forum Newbie / General discussionsReplies: 15Last Post: 16th Apr 2010, 01:11 -
Movement in my deinterlaced video doesn't look smooth ><
By onlinepen in forum Video ConversionReplies: 2Last Post: 25th Jul 2009, 08:53 -
configure XVID so virtualdub key I-frame's is able to go 1,2,3,4,...?
By Ghtpua in forum EditingReplies: 0Last Post: 21st Oct 2007, 15:05
