hi iam new to nero 7 i was just asking someone to help me to put 2 or 3 movies on to one dvd or were i can get help?
If you just need them to play one after the other then Baldrick already gave you the best suggestion. If you need a menu structure and you still want to use Nero then you load them into NVE and pick Make DVD movie or something like that. The wizard will walk you through. The best option is to separately convert each one to MPG2 compliant files with a converting tool of choice ( search ) so they are small enough to fit all three to a DVD less the nominal space required for Menus and other structure files as you author it in an authroing tool of choice ( Also search ) If these are full length movies they are going to look terrible as three movies is simply too much. Try to stay with 1-3 hour total playing time and you should achieve good to average results. More time than that and quality will plummet.
.No DVD can withstand the power of DVDShrink along with AnyDVD!
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 20:49 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 20:23 -
Can I install both Nero 8 & Nero 6 on same machine?
By OzarkBaby in forum Newbie / General discussionsReplies: 8Last Post: 3rd Jan 2008, 22:09 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 12:10 -
Nero Recode/Nero Digital users...
By siratfus in forum Video ConversionReplies: 4Last Post: 31st May 2007, 06:06
