Is there any way of adding a timer to virtualdub,so i can set it to record a
particular program at a set time.I like the way virtualdub captures and you
can choose your own codec,I'm using divx 5.21pro but i need a timer.If there is'nt can any one recommend any software that will allow me also to
configure the divx codec within the software
The Righteous Shall Inherit The Earth
There's this one, apparently for ATI capture cards: VideoWDMControl v2.2
Looks like this is one site for it: http://www.asvzzz.com/download.htm Watch out for the adware there.
There may be others, though this is the only one I have heard of. Never used it, though. -
I'd use Macro Magic and create macros to control the starting and stopping of virtualdub, then configure them to run through Windows Scheduled Tasks.
If in doubt, Google it. -
there is a program that works with virtual dub i have it somewhere i will email it to you when i find it, do a search on the web for virtual dub timer and you might find it. it was wrote just for virtual dub.
There are two that I am aware of. VD Start Pro and VD Timer. I think I used VD Start Pro. I don't remember if I found them on this site or not.
Darryl -
I once wrote one.
You'll find it at my links page together with some other versions based on it.
It's visual Basic w. sources so it's easy to modify for other purposes.
However I found that the sendkeys function used may not be 100% reliable, reason unknown. Try at your own risk.
Codecpage
First Timer..CPU Build Help.
By Texxas_Boy in forum ComputerReplies: 23Last Post: 20th Feb 2012, 20:20 -
Remote control WITH timer
By rdbierma in forum Newbie / General discussionsReplies: 0Last Post: 9th Mar 2010, 15:54 -
Capture to MPG on timer
By bolintx in forum Capturing and VCRReplies: 1Last Post: 5th Aug 2008, 17:20 -
SV2000 timer error messages
By Mr. Blue Sky in forum DVD & Blu-ray RecordersReplies: 8Last Post: 26th Aug 2007, 07:15 -
Help with Timer in Sony Vegas 6.0
By petersju in forum EditingReplies: 1Last Post: 11th Jun 2007, 19:54
