Hi,
I want to put 3 or 4 CD burners in one XP box to burn the same thing at the same time. Can this be done?
I now use Roxio Creator.
What else do I need other than the burners?
Oz![]()
You need Roxio to be able to support it - I know Nero does.
You need enough IDE connections also. Every mobo I've seen supports 4 (2 Primary, 2 Secondary), and generally you'll have one for your OS hard drive (unless you use SATA or RAID), and one for each optical DVD drive you have as well. You can buy PCI IDE expansion cards though, and each slot will support another two devices. Most cards I've seen have two slots on them, so 1 card gets you 4 extra devices. You should also have an adequate power supply - I'd suggest 450W ++.
My experience running two burners through Nero is that while it's a good idea in theory, and saves you having to load and unload discs inbetween, it tends to take roughly the same amount of time to burn anyway, especially if you've got burners sharing an IDE channel. Maybe a duplicator would serve you better ?If in doubt, Google it. -
Thanks...
The speed thing worries me a little..
I'll look at duplicators, if they are not too exy.
Oz
How to Record using 3 External Burners plus 2 Internal Burners with Speed
By mn072065 in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th May 2011, 19:27 -
When are they going to make multiple layer blu-ray burners and players?
By Onceler2 in forum DVD & Blu-ray WritersReplies: 5Last Post: 14th Jul 2008, 11:32 -
Problem with hooking up PC to TV
By cccccory in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2007, 03:59 -
Hooking up TV Tuner on PC?
By DonGallego28 in forum ComputerReplies: 9Last Post: 14th Sep 2007, 16:28 -
Helping with hooking things up..
By Superstar24 in forum Newbie / General discussionsReplies: 18Last Post: 23rd Jul 2007, 23:05
