I have videos encoded in 520kbps .rmvb format. If I were to convert them to mpg, what would be the equivalent bitrate for the .mpg file, or is it just the same?
Thanks.
MPG as in MPEG1 or MPEG2? Both are far less efficent than RV9EHQ/10 so the equiv bitrate would be higher. To be fair though if comparing equiv bitrates you would need to take the same source and convert it to rmvb and mpg, not convert the rmvb to mpg.
Also is the mpg going to be the same resolution or are you converting to (S)VCD or DVD? If the resoluton goes up, then so must the bitrate. -
I'm just converting the RMVBs to MPGs to be put onto a DVD, but I want to use the least bitrate as possible, while maintaining their original quality.
They're pretty much VCD quality, and I want to put as much as I can onto a DVD. -
Use an MPEG encoder that supports Constant Quality mode. Pick the quality you want (ie, how closely you want the output to match the input) and encode. No need to worry about bitrates (except obviously you must stay within the bounds of what's acceptable for DVD).
RMVB - AVS - M2V/MPG Audio Unsyncs
By koberulz in forum Video ConversionReplies: 7Last Post: 13th Aug 2011, 17:38 -
mpg-2 to ??? size and quality
By l4l4u in forum Video ConversionReplies: 4Last Post: 6th Nov 2009, 16:43 -
Convert rmvb to DVD with hight quality on mac
By raf0 in forum ffmpegX general discussionReplies: 7Last Post: 2nd Aug 2009, 07:21 -
RMVB Convert to Mpeg2 quality
By anfield7 in forum Video ConversionReplies: 1Last Post: 10th Dec 2008, 23:58 -
Need help converting SCM files to mpg or avi or rmvb or wmv
By US Guy in forum Video ConversionReplies: 3Last Post: 6th Aug 2007, 02:01
