Is it possible to burn a DVD with video encoded lower than 1850kbps? Because I want to burn a bunch of videos onto it, but their only VCD quality (~1000kbps). So it would kinda be a waste if space to encode them at 1850.
Hope someone can help me, thanks.
Results 1 to 15 of 15
You might want to look into 1/2 D1 or even VCD resolution. VCD video can be used in a DVD and it is 1150Kbps so you should be able to encode MPEG-2 down fairly low. Why not try a five minute sample and see what it looks like?
It's possible, but if they already meet VCD spec then you don't want to re-encode since the video already meets DVD spec. Just convert the audio to 48k and you're good to go.
Buy My Books -
The 1850kbps limit of mpeg1 DVDs is the maximum allowable bitrate. You can go as low as you want.
Most people probably don't realize this but its the same for VCDs and SVCDs. You can go as low as you want you just can't exceed 1150kbps. -
Nope. The VCD specs list 1150kbits as the maximum bitrate. There is no specified minimum.
So is Baldrick's VCD page wrong then ?Originally Posted by adam
https://www.videohelp.com/vcd.htm
https://www.videohelp.com/xvcd.htmPAL
Video:
1150 kbit/sec MPEG-1
Should it say 1150kbps MAX ?XVCD PAL
Video:
any kbit/sec MPEG-1 both variable and constant bitrate.If in doubt, Google it. -
Load the unlock template and then you can change the template settings however you want. Or just don't use any templates at all.
Do not use the VCD template as it uses non-compliant GOP settings for a DVD. Load the DVD template and then adjust the bitrate to whatever value you want. -
jimmalenko the xvcd description still seems accurate to me. The VCD description could probably be more specific but then again it might just cause more problems for people. I think Vitualis said that low bitrate VCDs didn't play well on his hardare VCD player. I doubt it would be a problem with DVD players but who knows. Practically speaking, 1150kbits is way too low as it is.
Oh, I get how to do it now. Thanks. The video files that I have are actually encoded in 520kbps .rmvb format.
What would be the equivalent bitrate for the .mpg file, or is it the same?
Thanks. -
The bitrate of source file and dest file are not related - (nor comparable) - even more so when you're using different codecs in source and dest. Only rule of thumb I've seen is to use around 4x source bitrate when encoding AVI (DivX/XviD) to DVD mpeg2.
No matter what, you always get a degradation of quality when reencoding. The higher bit rate you encode to, the lesser the degradation. In the end, it's always a compromise between quality and file size.
/Mats -
The maximum bitrate is actually 1151.929 kbits.Originally Posted by adam
vcd4ever.
I need to compress video to DVD but the quality is always lower...
By tzanaglio in forum Authoring (DVD)Replies: 6Last Post: 30th Apr 2009, 18:48 -
Lower video bitrate for a DIVX movie?
By DonGallego28 in forum Video ConversionReplies: 2Last Post: 10th Jan 2008, 20:09 -
Lower video quality from HDV to Bluray disc or HD DVD?
By Ollie6431 in forum Newbie / General discussionsReplies: 2Last Post: 13th Nov 2007, 13:25 -
4+hour DVD9, lower audio bitrate for better video?
By sdsumike619 in forum AudioReplies: 10Last Post: 24th Oct 2007, 12:24 -
Lower video encoding tips for small 7 inch screen
By hauns in forum EditingReplies: 5Last Post: 9th May 2007, 14:54
gotcha.
