i've got a SVCD mpeg2 with a bitrate of 2556Kbps
if i encode it to a DVD mpeg2 should i use same bitrate?
EDIT
i've asked this before, i must be getting forgetful in my old age.
No. DVD resolutions of 704x576 and 720x576 will require a higher bitrate. You are changing the resolution right? If you went with 352x576, then you could stay at the same bitrate, but even then, it seems kind of low.
Darryl -
You can use a bitrate calculator and find the max rate for your video's runtime. You are only going to bloat the file by increasing the rate though. The quality can only be degraded. There is no improving upon your source by re-encoding, no matter how high you jack the rate up.
flonk!
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 08:38 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 16:01 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 19:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 21:43 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2008, 00:54
