Is they a way to make a special features screen with Nero or Easy Cd Creator. Thanx fo' anyones help.
in EasyCD, this is just adding a second menu page and a separate play sequence for it. use the wizard, it should be pretty easy. the first menu is the regular menu, and points to the movie clips, the second menu is the special menu and points at the special feature clips. the NEXT/PREV keys on your remote should switch between the menus.
you need the 4.0 "deluxe" or 5.0 "platinum" with the special VCD creator program. my roommate had it, and i used it a couple years ago when i first started, but it's really not that good. nero is much better software, and either VCDImager or Philips VCD Toolkit are FAR better for authoring, though both take a little work. Nero will do simple text menus, the others will do full-motion video menus and all the other features most programs don't support.
AVStoDVD preview feature playes audio but no video (gray screen)
By granturissimus in forum Newbie / General discussionsReplies: 9Last Post: 12th Jan 2011, 15:27 -
Special Video Feature
By uthguy9 in forum MacReplies: 0Last Post: 1st May 2008, 17:03 -
Software suggestion to make special effect of voice
By bambam in forum AudioReplies: 4Last Post: 17th Mar 2008, 10:40 -
DVD special feature - music player?
By NotSoEasy in forum Authoring (DVD)Replies: 1Last Post: 23rd Jan 2008, 02:49 -
X.4.11 "Make sure that your startup disk has no spaces or special char
By etyrnal in forum ffmpegX general discussionReplies: 4Last Post: 20th Jan 2008, 23:23
